5 adc channels !!!!
exodia505
5 adc channels !!!!
PostPosted: Tue Feb 07, 2012 6:26 am     Reply with quote
Hello !!
I would like to know where is problem in using (division). As you see I use Timer2 to read, each Timer2 interrupt a value from Adc (successively ch1....to ch5). When I display idiv.rem it does take value(0,1,2,3,4)!!!!
I just want to get some correction.
Here's my code:
#include <16F877.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES XT                       //Crystal osc <= 4mhz
#FUSES NOPUT                    //No Power Up Timer
#FUSES PROTECT                  //Code protected from reads
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                    //No EE protection
#FUSES NOWRT                    //Program memory not write protected
#FUSES NODEBUG                  //No Debug mode for ICD
#include <LCD.C>
#include <Stdlib.h>
int a=0;
int val,val1,val2,val3,val4;
div_t idiv;
#int_TIMER2
void  TIMER2_isr(void)
idiv=div(a,5);
switch(idiv.rem)
case 0:set_adc_channel(0);
delay_us(20);
val=read_adc();
output_high(pin_c0);
a=a+1;
case 1:set_adc_channel(1);
delay_us(20);
val1=read_adc();
output_high(pin_c1);
a=a+1;
case 2:set_adc_channel(2);
delay_us(20);
val2=read_adc();
output_high(pin_c2);
a=a+1;
case 3:set_adc_channel(3);
delay_us(20);
val3=read_adc();
output_high(pin_c4);
a=a+1;
case 4:set_adc_channel(4);
delay_us(20);
val4=read_adc();
output_high(pin_c5);
a=a+1;
   setup_adc_ports(AN0_AN1_AN2_AN3_AN4);
   setup_adc(ADC_clock_div_8);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_1,99,16);
while(1){
if(input(pin_b1)==1)
lcd_putc("\f");
lcd_gotoxy(1,1);
printf(lcd_putc,"%2u",val);}
else{
lcd_putc("            ");
if(input(pin_b2)==1){
lcd_putc("\f");
lcd_gotoxy(10,1);
printf(lcd_putc,"%2u",val1);
}else{
lcd_putc("            ");
if(input(pin_b3)==1){
lcd_putc("\f");
lcd_gotoxy(10,1);
printf(lcd_putc,"%2u",val2);
else{
lcd_putc("            ");
if(input(pin_b4)==1){
lcd_putc("\f");
lcd_gotoxy(10,1);
printf(lcd_putc,"%2u",val3);
else{
lcd_putc("            ");
lcd_putc("\f");
lcd_gotoxy(10,1);
printf(lcd_putc,"%2u",val4);
else{
lcd_putc("            ");
   // TODO: USER CODE!!
NOway!!
PostPosted: Tue Feb 07, 2012 6:53 am     Reply with quote
One problem is that ISRs -MUST- be short and quick !!
That means the ISR should just set a flag then exit.
Having ANY kind of math function inside, especially division, is very bad.
The same holds true for delays( delay_us(), delay_ms()).
And switch/case statements.
You've got all 3 in your ISR !!
One answer is to just have the ISR set a 'flag', then in 'main' read that flag and if set, increment a variable( channel),then read the adc,display data,if channel=>5 reset channel to 0, then clear flag to 0.
Also
You should always add 'errors' to the use RS232(options) to keep the UART from 'freezing' as it only has a 2 byte buffer.
exodia505
PostPosted: Tue Feb 07, 2012 9:02 am     Reply with quote
thx anyway , it works now
NOway!!
PostPosted: Tue Feb 07, 2012 9:18 am     Reply with quote
The other appraoch that works for this, is to use a state machine, and do just one job at a time in the ISR.
(I slightly disagree with temtronics comment about switch/case in an ISR - it can work very well, and is as quick as a single array access - it just _must_ be used with care...). The delays involved in the code though are even worse, since the normal use of the read_adc function, takes 12 cycles of the ADC clock - typically 24uSec - add the acquisition delays, and things are getting very slow....
So:
#int_TIMER2
void TIMER2_isr(void) {
   static int8 state=0;
   switch(state++) {
   case 0:
      set_adc_channel(0); //This only used on the first pass
   case 1:
      read_adc(ADC_START_ONLY); //Normal re-entry point for the loop
   case 2:
      val=read_adc(ADC_READ_ONLY);
      set_adc_channel(1);
   case 3:
   case 4:
      val1=read_adc(ADC_READ_ONLY);
      set_adc_channel(2);
   case 5:
   case 6:
      val2=read_adc(ADC_READ_ONLY);
      set_adc_channel(3);
   case 7:
   case 8:
      val3=read_adc(ADC_READ_ONLY);
      set_adc_channel(4);
   case 9:
   case 10:
      val4=read_adc(ADC_READ_ONLY);
      set_adc_channel(0);
      state=1; //start again _at the second state_.
This takes 11 calls to the timer ISR to sample all five channels, but is _fast_ for each route. The switch takes about 18 machine cycles (note no 'default' - this is vital, since it forces a jump table to be made, rather than successive tests). Each call just sets a channel (a couple of machine cycles only), starts an ADC conversion (again just a couple of cycles), or reads a conversion (about 8 cycles).
No divisions - just set the state back to 0 on the last call.
No waiting for the ADC, start it on one ISR, and read it on the next.
Compiling this the _slowest_ route through the code takes under 40 machine cycles on a PIC16.
exodia505
PostPosted: Tue Feb 07, 2012 10:47 am     Reply with quote
yes, that's true i just changed two things and it worked well
NOway!!
PostPosted: Tue Feb 07, 2012 10:52 am     Reply with quote
The only issue I have with Case inside the ISR, is in timing. Depending on how the 'case' is made it might take too long to be effective inside the ISR. Looking at the listing will see how much code is created.
As we all have found out, code always seems to 'grow'....and ISRs should
always be fast !
The bottom line is that if it works, great ! BUT if you run into 'issues', reduce ISR code to the minimum.
PostPosted: Tue Feb 07, 2012 3:53 pm     Reply with quote
always be fast !
Yes.
This is where I am with 'must be used with care'. Setup by someone who has worked out CCS's rather 'non plain' rules for how switches are decoded, so a jump table is used, it is quite fast. However the point Temtronic is making here is totally valid you _need_ to actually study the timings to be sure that it is coding the way you expect.
exodia505
PostPosted: Fri Feb 10, 2012 4:45 am     Reply with quote
if i want to send adc values to pc via serial port and i use this :
printf("%2u %2u %2u %2u %2u\n\r",val,val1,val2,val3,val4);
will be fine? i mean is it easy to separare between data in vb.net ?
what you advice me to do ?
thanks
NOway!!
PostPosted: Fri Feb 10, 2012 6:45 am     Reply with quote
How easy VB.NET works is up to you( I don't use it)
If you insert commas you creat 'CSV' data, Excel will display perfectly
original code...
modified code...
printf("%2u , %2u , %2u , %2u , %2u\n\r",val,val1,val2,val3,val4);
Also, you should read up on VB to see if \n\r is the 'end of line' delimiter or if \r\n is the 'end of line' delimiter.
I know for CSV files it's different than QB45.
