at45db041 library problem
koray_duran
PostPosted: Tue Feb 07, 2012 3:02 am     Reply with quote
When try to compile my codes at45db041 library creates errors. It seems an easy error but i couldn't figure out why it occurs. Please take a look.
Here is the error:
line 30(1,2): expecting an identifier //int16 g_ExtFlashCurrPage; - line 30
line 30(7,25): expecting a (
Here is the library:
Deleted.
Code deleted.
Reason: Forum Rule #10.
10. Don't post the CCS example code or drivers
Forum rules:
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
- Forum Moderator
PostPosted: Tue Feb 07, 2012 5:21 am     Reply with quote
Do a search on the forum for questions asking about errors in lines that appear OK.
Generally the reason is that there is something wrong several lines earlier. Possibly even in the file that loads this one, and the compiler flags the error, when it can no longer 'cope', rather than where the fault actually exists.
