Is it possible to read a constante as high and low byte?
Ivar Johnsrud
PostPosted: Tue Nov 12, 2002 12:11 pm     Reply with quote
Does anyone know if it is possible to read a
constant as high and low byte, something like this:
#define COUNT 0x10FF
#asm
movlw HIGH COUNT
movwf TMR0H
movlw LOW COUNT
movwf TMR0L
#endasm
-Ivar
___________________________
Original Post ID: 8808
Neutone
Re: Is it possible to read a constante as high and low byte?
PostPosted: Tue Nov 12, 2002 12:31 pm     Reply with quote
:=Does anyone know if it is possible to read a
:=constant as high and low byte, something like this:
:=#define COUNT 0x10FF
:=#asm
:= movlw HIGH COUNT
:= movwf TMR0H
:= movlw LOW COUNT
:= movwf TMR0L
:=#endasm
:=-Ivar
This may be what you are looking for.
set_timer0(COUNT);
Original Post ID: 8810
Ivar Johnsrud
PostPosted: Tue Nov 12, 2002 12:33 pm     Reply with quote
:=:=Does anyone know if it is possible to read a
:=:=constant as high and low byte, something like this:
:=:=#define COUNT 0x10FF
:=:=#asm
:=:= movlw HIGH COUNT
:=:= movwf TMR0H
:=:= movlw LOW COUNT
:=:= movwf TMR0L
:=:=#endasm
:=:=-Ivar
:=This may be what you are looking for.
:=set_timer0(COUNT);
Yeah, I just realized, thanks.
-Ivar
Original Post ID: 8812
Sherpa Doug
Also check out MAKE8()
PostPosted: Tue Nov 12, 2002 12:50 pm     Reply with quote
Original Post ID: 8813
johnpcunningham
PostPosted: Tue Nov 12, 2002 1:31 pm     Reply with quote
<font face="Courier New" size=-1>Another idea for you (like a UNION) using 16F877:
//register locations
#byte TMR1L 0x0E
#byte TMR1H 0x0F
void main(){
int16 timer1_long;
//get 16 bit value of timer
timer1_long = make16(TMR1H, TMR1L);
//set timer values
TMR1L = 0xAA;
TMR1H = 0xBB;
while(1){};
}</font>
Original Post ID: 8814
Mark
PostPosted: Tue Nov 12, 2002 3:05 pm     Reply with quote
Yet another way....
using 16F877:
long TMR1;
#locate TMR1 = 0x0E
#define TIMERVALUE 0xAA55
TMR1 = TIMERVALUE;
Original Post ID: 8816
