18F2550 and internal clock ??
spilz
PostPosted: Mon Jan 30, 2012 1:52 pm     Reply with quote
hey everybody !
I have a problem that i don't know/understand how to solve :
I want to use a 18f2550 at 4MHz without quartz, but I don't find how to configure the .h file in my project to do it.
What is the Fuse setting to do it?
I try a lot of different possibility, but i don't find a good one
Can you help me please? if some one use this pic without external component, can he/she send me his .h file
For example I tried:
#FUSES INTRC                    //Internal RC Osc, no CLKOUT
#FUSES MCLR                  //Master Clear pin enabled
#FUSES FCMEN                    //Fail-safe clock monitor enabled
but when i put this code in Main :
while(1){
      output_high(pin_A2);
      delay_ms(5);
      output_low(pin_A2);
      delay_ms(5);
I have in reality 650ms high, 650ms low
thanks for your help
spilz
Mike Walne
internal oscillator
PostPosted: Mon Jan 30, 2012 3:55 pm     Reply with quote
It looks like your internal oscillator is running at the 18F2550's default 31kHz frequency.
I have not used the 18F2550 but suspect you need to add "setup_oscillator(OSC_4MHZ)" to your initialisation code.
Mike
spilz
PostPosted: Mon Jan 30, 2012 4:05 pm     Reply with quote
it works !!!
thank you so much !!
