sahu77
horse riding on 16*2 lcd with flex_lcd.c |
Posted: Sat Jan 28, 2012 1:59 pm |
Few day ago I found HI-TECH code. Its work 16*2 lcd. Its working as display on lcd like horse riding on 16*2 lcd. So I decide, I will convert on CCS C, those are as...
Main Program
disable_interrupts(GLOBAL);
// Initilize RAM Variables
//Timer1 Init
//ADC Init
while (TRUE)
lcd_init(); // Always call this first.
for(;;){
for(ctr=0;ctr<17;ctr++){
horse1();
lcd_gotoxy(ctr,1);
for(a=0;a<=3;a++) lcd_putc(a);
lcd_gotoxy(ctr,2);
for(a=4;a<=7;a++) lcd_putc(a);
delay_ms(500);}
horse2();
lcd_gotoxy(ctr,2);
lcd_gotoxy(ctr,1);
void horse1(void)
int i,s,adres=64;
const byte karakter_[8][8]=
{(0b00000) ,(0b00000) ,(0b00000) ,(0b00000) ,(0b00000) ,(0b00111) ,(0b01111) ,(0b11110)},
{(0b00000) ,(0b00000) ,(0b00000) ,(0b00000) ,(0b01110) ,(0b11111) ,(0b11111) ,(0b11111)},
{(0b00000) ,(0b00000) ,(0b00000) ,(0b00000) ,(0b00111) ,(0b11111) ,(0b11111) ,(0b11111)},
{(0b00000) ,(0b00010) ,(0b11111) ,(0b11111) ,(0b11111) ,(0b11011) ,(0b10011) ,(0b10000)},
{(0b00000) ,(0b00000) ,(0b00000) ,(0b00000) ,(0b00001) ,(0b00001) ,(0b00001) ,(0b00000)},
{(0b11111) ,(0b11111) ,(0b11011) ,(0b10010) ,(0b00001) ,(0b00001) ,(0b10001) ,(0b00000)},
{(0b11111) ,(0b11111) ,(0b00001) ,(0b00001) ,(0b00001) ,(0b00001) ,(0b00000) ,(0b00000)},
{(0b11000) ,(0b11100) ,(0b00100) ,(0b01000) ,(0b10000) ,(0b00000) ,(0b10000) ,(0b00000)},
for(i=0;i<=7;i++)
lcd_send_byte(0,adres);
for(s=0;s<=7;s++) {
lcd_send_byte(1,karakter_[i][s]);
adres=adres+8;
void horse2(void)
int i,s,adres=64;
{ (0b00000) ,(0b00000) ,(0b00000) ,(0b00111) ,(0b01111) ,(0b01110) ,(0b11100) ,(0b11000)},
{ (0b00000) ,(0b00000) ,(0b00000) ,(0b01111) ,(0b11111) ,(0b11111) ,(0b11111) ,(0b11111)},
{ (0b00000) ,(0b00000) ,(0b00000) ,(0b00011) ,(0b11111) ,(0b11111) ,(0b11111) ,(0b11111)},
{ (0b00000) ,(0b00001) ,(0b11111) ,(0b11111) ,(0b11111) ,(0b11011) ,(0b10011) ,(0b10000)},
{ (0b10011) ,(0b10011) ,(0b00010) ,(0b00010) ,(0b00100) ,(0b00000) ,(0b00000) ,(0b00000)},
{ (0b11111) ,(0b00111) ,(0b01110) ,(0b00110) ,(0b00001) ,(0b00000) ,(0b00000) ,(0b00000)},
{ (0b01111) ,(0b00111) ,(0b10011) ,(0b01111) ,(0b00000) ,(0b10000) ,(0b00000) ,(0b00000)},
{ (0b10000) ,(0b11000) ,(0b01100) ,(0b00100) ,(0b00010) ,(0b00001) ,(0b00000) ,(0b00000)},
for(i=0;i<=7;i++)
for(s=0;s<=7;s++) {
adres=adres+8;
Original code is here:
http://shahrulnizam.com/pic-lesson-custom-character-lcd/ _________________ sahu |
sahu77
Posted: Mon Jan 30, 2012 10:56 am |
Code: | lcd_gotoxy(ctr,1);
lcd_gotoxy(ctr,2);
delay_ms(500);}
lcd_gotoxy(ctr,1);
Use for 1st line 1 to 4, 5*7 matrix, &&
lcd_gotoxy(ctr,2);
use for 2nd line 1 to 4, 5*7 matrix, is right ????
But display give image 1st line, 1 to 8 & then come 2nd line 1 to 4, 5*7 matrix.
pl help me ..... _________________ sahu |
Joined: 01 Jul 2010 Posts: 9163 Location: Greensville,Ontario
Posted: Mon Jan 30, 2012 11:38 am |
You don't show what LCD driver you're using or the actual LCD itself.
It could be a problem with the translation from the original program or a driver / LCD mismatch.
The link didn't work for me, so I can't comment further on the 'translation' from it and without knowing the make/model of the LCD as well as the driver info...,can't help there either. |
sahu77
Posted: Mon Jan 30, 2012 1:22 pm |
temtronic wrote: | You don't show what LCD driver you're using or the actual LCD itself.
I use flex_lcd.c.
If know any problem I can post here original code, but it is HI-TECH . Can I post here ? _________________ sahu |
Posted: Mon Jan 30, 2012 1:55 pm |
Well there's nothing wrong with the flex_lcd driver..
Sounds like you've got the wrong addresses for the lines on your LCD unit. You'll have to read the datasheet for your LCD to see though. |
sahu77
Posted: Tue Jan 31, 2012 10:02 am |
temtronic wrote: | Well there's nothing wrong with the flex_lcd driver..
Right now no need for datasheet for my LCD. Because right now I use Oshonsoft sim. _________________ sahu |
Posted: Tue Jan 31, 2012 10:37 am |
Gee next time you ask a question tell us all, upfront, you're using a SIMULATOR !!!
That will really help!! |
sahu77
Posted: Tue Jan 31, 2012 11:44 am |
temtronic wrote: | Gee next time you ask a question tell us all, upfront, you're using a SIMULATOR !!!
ok sorry - sorry
Oshon Soft SIMULATOR _________________ sahu |
Mike Walne
Horse image |
Posted: Wed Feb 01, 2012 5:06 am |
Link worked for me. It produces these two images of a horse on LCD. I do not propose to help with translation from Hi-Tec to a simulator.
horse1
horse2
Mike |
sahu77
Re: Horse image |
Posted: Wed Feb 01, 2012 9:29 am |
My propose for translating it is, because I add it in rest of my code. Which is in ccs c. _________________ sahu |
Mike Walne
Simulators |
Posted: Wed Feb 01, 2012 2:19 pm |
What the real experts on this forum are saying loud and clear is "SIMULATORS ARE A WASTE OF TIME". You will get more help when you use hardware. All simulators are flawed, there are enough problems to solve without getting into sorting out other issues.
Mike |
