Settings timer1 for have 20µs delay
joseph20480
PostPosted: Fri Jan 27, 2012 3:47 pm     Reply with quote
I have a question about the timer utilisation....
Timer1 16 bits, 2^16=65536.
20Mhz-> 1 /20Mhz=50ns....x4=200ns.
>>So 65536-64536=100.....100*200ns=20µs.... in theory...
In fact, with a scope, i have 30.40µs...
>> (With timer0, i have the same problem)
If someone could say me why ???
#include <18F4523.h>
#fuses NOWDT, HS
#int_timer1
void interruption_20us()
   set_timer1(65436);
   output_high(pin_a0);
   output_low(pin_a0);
   set_timer1(65436);
   setup_timer_1(T1_internal|T1_DIV_BY_1);
   enable_interrupts(int_timer1);
   enable_interrupts(global);
   for(;;)
PostPosted: Fri Jan 27, 2012 4:04 pm     Reply with quote
Read this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=43399
Mike Walne
Timer error
PostPosted: Sat Jan 28, 2012 4:13 am     Reply with quote
As PCM programmer points out, most of your timing error is due to the time taken to get into the interrupt routine.
I tested your program with MPLAB SIM and got a repeat rate of 150 instruction cycles, which is near enough your value for me.
I then replaced your interrupt line
   set_timer1(65436);
with the lines
signed int16 x;
   x = get_timer1();
   x-=100;
   set_timer1(x);
The repeat rate is now 113 instruction cycles. The error is now essentially the time taken to process the timer1 register. I haven't had time to test it with a 'scope, but I usually find that the MPLAB SIM is out by a few cycles so have to adjust empirically on the real hardware.
Mike
