Sprintf error 114
alimary158
Sprintf error 114
PostPosted: Thu Jan 26, 2012 11:32 am     Reply with quote
Hello, i am using a command
sprintf(pressure,"Valore=%d\r\n",RxBaseADC[RxTailADC++]);
where the RxBaseADC[RxTailADC++] is a int16[32]
but when i try to compile it gives me this error:
error 114: sprintf format type is invalid
here is my full code
in particular the RxBaseADC[RxTailADC++] variable is coming from a ring buffer that i implement in the code
has anyone any suggestion? i don't know why this error is coming
thank you all
#include <PIATTAFORMA.h>
#ifndef DWORD
#define DWORD int32
#ifndef WORD
#define WORD int16
DWORD get_fattime(void)
   return 0;
#include <ff.h>
int16 data=85;
int16 value=0;
//int8 databyte1=0;
//int8 databyte0=0;
//int8 TIME_H=0,TIME_L=0, CKS=0;
char mesg[32];
#define RxADCQsize 32
volatile int16   RxBaseADC[RxADCQsize];
// Rx Ring Buffer control
volatile BYTE   RxHeadADC;
BYTE   RxTailADC;
void init_pic(void)
// void init_pic(void)
// Initialise the hardware defaults
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
#ifdef PCmp_Def
   // setup_comparator
   CMCON = PCmp_Def;   // initialise comparators
   // initialse port A
   output_a(PA_DefData);
   set_tris_a(PA_DefTRIS);
   // initialise port B
   port_b_pullups(TRUE);
   output_b(PB_DefData);
   set_tris_b(PB_DefTRIS);
   // initialise port C
   output_c(PC_DefData);
   set_tris_c(PC_DefTRIS);
#ifdef PD_DefData
   // initialise port D
   output_d(PD_DefData);
   set_tris_d(PD_DefTRIS);
#ifdef PE_DefData
   // initialise port E
   output_e(PE_DefData);
   set_tris_e(PE_DefTRIS);
#ifdef PF_DefData
   // initialise port F
   output_f(PF_DefData);
   set_tris_f(PF_DefTRIS);
#ifdef PG_DefData
   // initialise port G
   output_g(PG_DefData);
   set_tris_g(PG_DefTRIS);
#ifdef PH_DefData
   // initialise port H
   output_h(PH_DefData);
   set_tris_h(PH_DefTRIS);
#ifdef PJ_DefData
   // initialise port J
   output_j(PJ_DefData);
   set_tris_j(PJ_DefTRIS);
#INT_timer2
void timer2_isr()
   //disable_interrupts(global);
   //data=read_adc(); //This function will read the digital value from the ADC
   //databyte1=make8(data,1); //estraggo byte high
   //databyte0=make8(data,0);//estraggo byte low
   //Covertire dato intero in una stringa
  // sprintf(mesg,"%d",data);
   RxBaseADC[RxHeadADC++]=data;
   // test if ring buffer wrap is required
   if (RxHeadADC >= RxADCQsize)
      RxHeadADC = 0;
  // enable_interrupts(global);
void main (){
    FIL fsrc;            // file structures
    FRESULT result;     // FatFs function common result code
    WORD btw, bw;       // File R/W count
    FRESULT   FS_Status;
    char pressure[64];
   disable_interrupts(GLOBAL);
   restart_wdt();
   // Pic Inizialization
   init_pic();
   //setup_adc_ports(sAN1);
   //setup_adc(ADC_CLOCK_INTERNAL);
   //set_adc_channel(1);
   setup_timer_2 (T2_DIV_BY_16, 255, 1);
   RxHeadADC=0;
   RxTailADC=0;
   //clear_interrupt(INT_RDA);
   //enable_interrupts(INT_RDA);
  // enable_interrupts(int_timer2);
   do
      FS_Status = f_mountdrv();
   while (FS_Status);
   //Il file creato si chiamera pressure.txt
   strcpy(pressure,"event4.txt");
   //F_OPEN(): if the file already exist the datas will be appened. if the file doesnt exsist it is created
   result  = f_open(&fsrc,&pressure, FA_OPEN_ALWAYS | FA_WRITE);
  //Find the end of the file to append datas
   result = f_lseek(&fsrc, fsrc.fsize);
   //write a string delimiter to each append data log
            strcpy(pressure, "\r\nNewTrial \r\n");
            btw=strlen(pressure);
            result = f_write(&fsrc,pressure, btw, &bw);
   //checking the buffer tail and head
   disable_interrupts(int_timer2);
   if (RxHeadADC != RxTailADC)
      // here we have data waiting to be written
      if (RxTailADC >= RxADCQsize)
            RxTailADC = 0;
          f_write(&fsrc,pressure,strlen(pressure),&bw);
   result = f_sync(&fsrc);
   f_close(&fsrc);
PostPosted: Thu Jan 26, 2012 11:56 am     Reply with quote
hmmmmmmmm.....
My guess is that the compiler doesn't like the ++ added to the end of the varibale RxTailADC.
I'd suggest trying something like..
dummy_value=1;
sprintf(pressure,"Valore=%d\r\n",RxBaseADC[dummy_value]);
and see what happens.
If the error goes away then you've found out why there is the problem
alimary158
PostPosted: Thu Jan 26, 2012 12:17 pm     Reply with quote
i have changed my code in this way:
Int16 dummy_value;
dummy_value=RxBaseADC[RxTailADC];
RxTailADC=(RxTailADC+1);
sprintf(pressure,"%d",dummy_value);
but the error keeps going!!!!!!!!
PostPosted: Thu Jan 26, 2012 12:53 pm     Reply with quote
%d specifies a signed integer ( 8 bits) -128 to +127
dummy_value has been declared a long integer(16 bits)
if you press F11 with your project open, you''ll access the onscreen Help files that CCS provides..
Douglas Kennedy
PostPosted: Thu Jan 26, 2012 2:06 pm     Reply with quote
temtronic makes a good point here. Lets hope the F11 help key isn't missing on some keyboards. Also a quick look at a beginners C code tutorial especially basic syntax might also be a useful strategy for some. Chances are if you are new to CCS then the error you have has already been made before so searching C syntax and this board often will lead to a faster solution.
alimary158
PostPosted: Thu Jan 26, 2012 2:23 pm     Reply with quote
Hello yes the problem was in the %d that i changed in %lu now this is working!
thank you so much
