How can use temp_seconds
sahu77
PostPosted: Thu Jan 19, 2012 9:30 am     Reply with quote
I can't understand how I can use temp_seconds in TIMER1_isr ?
Now I'm use like this ------
/*******************************************************  Timer1 Interrupt, executed every 10 ms
#INT_TIMER1
void TIMER1_isr(void)
   // Increment time_elasped to keep track of ms
   time_elasped++;
   // Increment seconds variable if 1000 ms have passed
   if (time_elasped == 100)  // @ 1000 ms
        seconds++;
        time_elasped = 0;
   if (seconds != temp_seconds) // now (ch_3>=950)
         odd_or_even = seconds % 2;
         // Even?  Yes
         if (odd_or_even == 0)
            output_high(L3);
            output_low(L3);
      if (seconds != seconds) // now (ch_3<950)
            output_low(L3);
   //Reset Timer 1
   set_timer1(60545);
   clear_interrupt(INT_TIMER1);
 Reads Form AN3 ADC_Value for lod sence
void Process_ch_3(void)
      if (ch_3<950)
      over_lod_flag = off;
      ol_counter_flag = off;
      seconds=seconds;
      if (ch_3>=950)
      seconds=temp_seconds;
      BlinkLED2();
     lcd_putc("\fOVER SENCE PLASE\n");
     lcd_putc(" REDUCE LOAD");  //
     if ( rest_sec=BLINK_SEC - temp_seconds);
      ol_counter_flag =on;
      rest_sec--;
      lcd_gotoxy(1,1);
      printf ( lcd_putc,"\fSECONDS LEFT %lu ",rest_sec);
      lcd_gotoxy(1,2);
      printf ( lcd_putc,"FOR OUTPUT CUT");
But temp_seconds sec not working.
I want if (ch_3>=950), then temp_seconds work. But it work every time [if (ch_3>=950) or if (ch_3<950) ].
pl help me ...
sahu
PostPosted: Thu Jan 19, 2012 10:24 am     Reply with quote
I can't see anywhere in these 'code segments' that you actually assign any value to the variable temp_seconds and I must assume you've declared it as an INT16 NOT the default of INT8.
Wayne_
PostPosted: Thu Jan 19, 2012 10:33 am     Reply with quote
This must be a joke or a homework assignment.
sahu77has answered his own question within the question itself.
There are no variable definitions.
There is an error in the third condition in the interrupt
(ch_3>=950)
(ch_3<950)
What does != mean ?
sahu77
PostPosted: Thu Jan 19, 2012 11:23 am     Reply with quote
yes int16 temp_seconds ;
      rest_sec--;
      lcd_gotoxy(1,1);
      lcd_gotoxy(1,2);
use here temp_seconds
sahu
PostPosted: Thu Jan 19, 2012 11:55 am     Reply with quote
You still have not shown how values are stored INTO temp_seconds only examples of it being used for some calculations.
PostPosted: Thu Jan 19, 2012 5:13 pm     Reply with quote
checkout what WAYNE_ sez dude!!!
last time i checked seconds BETTER always ==seconds.
under what conditions will this branch be taken ??
if this was a lunch order in CCS C - you'd starve to death LOL
Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy
PostPosted: Fri Jan 20, 2012 5:20 am     Reply with quote
There is also your other thread on this same RTC function where you never responded to. Very impolite.
bkamen
PostPosted: Fri Jan 20, 2012 7:12 am     Reply with quote
      rest_sec--;
      lcd_gotoxy(1,1);
      lcd_gotoxy(1,2);
that's not a declaration. That's a use.. in an IF... as an argument, not a destination.
Typically it's bad form to assign values in conditional statements. (I read somewhere).
Consider rewriting to use == for rest_sec's comparison...
and you still need a declaration of INT16 (or more likely unsigned int16) somewhere for temp_seconds.
