installed ccs again and it worked
koenbielen
PostPosted: Tue Jan 17, 2012 2:30 pm     Reply with quote
asmboy
PostPosted: Tue Jan 17, 2012 2:36 pm     Reply with quote
first off
*** Error 18 "Jaga_DBE_PRO.c" Line 1(9,20): File can not be opened
Not in local N:\Projects\Jaga\DBE_PRO\002_PIC_Software\001_CCS\001_Sources\18F4525.h"
seems to say an essential FILE or path -- has gone missing on you
PostPosted: Tue Jan 17, 2012 2:39 pm     Reply with quote
It can't find that file. Where is it ?
Here are some previous threads on this error message.
You may not have the exact same problem, but the solutions
might still work for you:
http://www.ccsinfo.com/forum/viewtopic.php?t=47002
http://www.ccsinfo.com/forum/viewtopic.php?t=42840
koenbielen
PostPosted: Tue Jan 17, 2012 3:21 pm     Reply with quote
PostPosted: Tue Jan 17, 2012 3:32 pm     Reply with quote
What is N: ? Is that a network drive ? Maybe ask your system administrator about it. Maybe some permission attribute was changed.
koenbielen
PostPosted: Tue Jan 17, 2012 3:39 pm     Reply with quote
n:\ is my datadrive on my local PC so no network
PostPosted: Tue Jan 17, 2012 4:12 pm     Reply with quote
It would have been better to leave your post and title as it was, and just
add the solution, so it would be in the archives for others.
