How to drive LED on PIC24FJ128GB110 ?
boomsomehand
PostPosted: Sun Jan 15, 2012 12:50 pm     Reply with quote
I need programming to drive LED on PORT A0.
Thanks !
ezflyr
PostPosted: Sun Jan 15, 2012 4:53 pm     Reply with quote
Is this a trick question????
At the top of your program (you have a program???) do this:
#define LED Pin_A0
Inside your Main routine, do this:
output_high(LED);
Connect the anode of the LED to Pin A0. Connect the cathode of the LED to one end of a 300 ohm resistor (value is not super critical), and connect the other end of the resistor to gnd.
When you run your program the LED should light.
John
RoGuE_StreaK
PostPosted: Sun Jan 15, 2012 5:44 pm     Reply with quote
Yes, that's a rather vague question...
What kind of LED? A little standard 20mA job, or a 3Amp Cree? If the former, then yes you can direct-drive from a pin (well, it's rated at 18mA, so anything under that), if the latter (or over 18mA) then you'll need to drive another circuit, essentially using the pin to turn the other circuit on/off, eg with a transistor or via an "enable" pin of an LDO regulator, a constant-current sink, or something like that.
What do you want to do with it? Just blink, fade it, ...? All cases essentially boild down to turning the LED on and off, just depends on how regularly and how fast. ezflyr has shown how to turn the pin on, you can vary timing between on and off to create different brightnesses (look up "PWM"), or you can use the onboard hardware PWM to take care of the timing for you.
Douglas Kennedy
PostPosted: Sun Jan 15, 2012 8:03 pm     Reply with quote
Well, it just might be a bit more complicated.
Port A0 mustn't be analog and shouldn't be open drain unless you are planning on an external pull up.
