Clearing LCD
Chaud
Clearing LCD
PostPosted: Thu Jan 12, 2012 8:33 am     Reply with quote
hello, there is a command to clear all characters from LCD??
I try lcd_putc(""); but it doesn't work as i want.
sahu77
Re: Clearing LCD
PostPosted: Thu Jan 12, 2012 9:18 am     Reply with quote
I try lcd_putc(""); but it doesn't work as I want.
check LCD driver
////                             LCDD.C                                ////
////                 Driver for common LCD modules                     ////
////  lcd_init()   Must be called before any other function.           ////
////  lcd_putc(c)  Will display c on the next position of the LCD.     ////
////                     The following have special meaning:           ////
////                      \f  Clear display                            ////
////                      \n  Go to start of second line               ////
////                      \b  Move back one position                   ////
////  lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)    ////
////  lcd_getc(x,y)   Returns character at position x,y on LCD         ////
sahu
