0 to 100Hz reading
MAKInnovation
0 to 100Hz reading
PostPosted: Thu Jan 12, 2012 12:35 am     Reply with quote
Need a simple code to read input frequency of 0 to 100Hz
Ash
PostPosted: Thu Jan 12, 2012 12:39 am     Reply with quote
Use the forum's search page to search for:
Tachometer
also search for
PicBasic Count Command
In the last case, set the search page to: Search for All Terms
Links to forum search page:
http://www.ccsinfo.com/forum/search.php
SherpaDoug
PostPosted: Thu Jan 12, 2012 7:13 am     Reply with quote
You need to think carefully about reading near 0Hz. To read 1Hz will usually take a full second. Reading 0.1Hz will take 10 seconds. 0Hz will literally take forever. What resolution do you need and how long can you wait?
PostPosted: Thu Jan 12, 2012 7:34 am     Reply with quote
for low frequencies - you are better off using the frequency of interest
as a PERIOD GATE, applied to a (16 bit TMR1) timer that is counting the PICS ( crystal - 16 mhz - prescaled to 1 usec ?) clock - and doing the math to calculate the frequency .
then you can have a frequency measurement of each complete cycle of the unknown.
SherpaDoug
PostPosted: Thu Jan 12, 2012 11:02 am     Reply with quote
Even with a period gate, reading a 0.1Hz signal will still take 10 seconds. You need to time from + edge to + edge or - edge to - edge, unless you KNOW it is a 50% duty cycle in which case it is still 5 seconds.
To accurately display 0Hz with 0.1 resolution you need to look for 10 seconds and see no more than one countable edge to be sure.
PostPosted: Thu Jan 12, 2012 1:32 pm     Reply with quote
If the waveform you want to count is close to 50% duty cycle - you can edge trigger on a b port change - to count a HALF cycle too i suppose.
Then - another - but dicer way that can be used.
Add a 74HC4046 - and a VCO output divider - divide by 8 or 16 - and do a PLL lock to the 4046 oscillator out incoming. YES there will be PLL lock time - but if the signal is not whipping about TOO fast in the freq/time domain -
- this can cut down the read gate time too - and possibly be of some help.
MAKInnovation
PostPosted: Thu Jan 12, 2012 11:37 pm     Reply with quote
Can i use a Frequency to Voltage converter like LM331 or LM2907 and then read converter output value with uController ADC
PostPosted: Fri Jan 13, 2012 3:06 am     Reply with quote
Not with any sort of resolution.
You need to specify rather better what you actually need.
Resolution?.
Accuracy?.
What is the real range, does it genuinely go to '0'?.
How fast should the update be?.
Zero, really is the problem area. Normally the approach is to accept anything under some specific rate as 'zero', and write the code to avoid things like maths overflows when this is reached. You can speed up responsiveness, with tricks, like phase locking a higher frequency onto the signal to be measured, but all fail when you get to '0'.
MAKInnovation
PostPosted: Fri Jan 13, 2012 4:14 am     Reply with quote
Thanks Brother;
Yes the frequency could be zero
Resolution is not really important, it could be 1hz, 2hz.... or 1hz or 3hz...
But measurement must be accurate.
Regards;
Ash
SherpaDoug
PostPosted: Fri Jan 13, 2012 7:12 am     Reply with quote
What is the source of the signal? Is it some sort of spinning wheel with a notch or magnet on it? Could it have several notches or magnets, giving a higher frequency to measure?
Having the uP measure a PLL locked to a multiple of the signal makes life easier for the uP, but doesn't actually help the system any. This is because the PLL can't track the input if there are no input edges for it to respond to. You have moved the problem from the uP to the PLL but it is the same problem.
Now if you have an analog sine wave input instead of a square wave there is lots of information in a fraction of a cycle.
SherpaDoug
PostPosted: Fri Jan 13, 2012 7:21 am     Reply with quote
A while back I had a project with a spinning disk whose speed had to be reported in part for feedback to the motor driving it.
One magnet and hall sensor would not give the required update rate at low speeds. We could use multiple magnets, but could not guarantee they would be evenly spaced around the wheel, so reading from one magnet to the next would give reported speed jitter.
So I had 4 magnets with one sensor and had to keep 4 distinct times, magnet A to magnet A, magnet B to magnet B, etc. I reported speed 4 times per revolution with no jitter. But I still could not report anything until the first rotation was complete.
MAKInnovation
PostPosted: Sat Jan 14, 2012 12:08 am     Reply with quote
I am going to use this hall effect sensor for my application
http://common.leocom.jp/datasheets/142894_21112.pdf
Ash
