Sending control codes to a thermal printer....
John Morley
PostPosted: Tue Jan 10, 2012 11:18 am     Reply with quote
Hi All,
I'm having some trouble sending control codes to a thermal printer. The documentation says I need to send the following:
ASCII: ESC 7 N1 N2 N3
or
Decimal: 27 55 N1 N2 N3
I tried using this code:
     fputc(27, Printer);
   fputc(55, Printer);
     fputc(7, Printer);
        fputc(HeatTime, Printer);       //Default 80 or 800us
   fputc(HeatInterval, Printer);   //Default 2 or 20us
but that didn't work, it just caused the print to output some garbage.
I also tried:
   fprintf(Printer, "%u", 27);
   fprintf(Printer, "%u", 55);
   fprintf(Printer, "%u", 7);
   fprintf(Printer, "%u", HeatTime);
   fprintf(Printer, "%u", HeatInterval);
with the same result.
So, what is the proper method to send these types of control codes?
Thanks,
John
John Morley
PostPosted: Tue Jan 10, 2012 1:17 pm     Reply with quote
I would check the baud rate and other aspects of the RS-232.
If you need more help, post a link to the website for the printer.
John Morley
PostPosted: Tue Jan 10, 2012 1:43 pm     Reply with quote
It's not a connection or baud rate issue as I'm able to successfully print text data to the printer. There are several configuration settings, however, such as the amount of time the print head heater is active that I don't seem to be able to change.
Here is a link to the printer manual on the SparkFun website: http://www.sparkfun.com/datasheets/Components/General/A2-user%20manual-1.pdf
The command I am trying to use, 'Control Parameter Command', is found in section 5.2.9 of the manual.
Thanks!
John
John Morley
RF_Developer
PostPosted: Wed Jan 11, 2012 3:06 am     Reply with quote
fputc() should have worked. Its the normal way to send out arbitary codes/characters to a named serial stream. Your first code *should* have worked, unless there is some other problem. What is your #use rs232 line?
RF Developer.
PostPosted: Wed Jan 11, 2012 4:05 am     Reply with quote
Your data is wrong.
Page 10 of the manual gives the command to set the times, as:
ESC 7 n1 n2
Set printing para. Heat & break time, max heat dot
The code for this is:
   fputc(27, Printer);
   fputc('7, Printer);
or
   fprintf(Printer,"\x1B7%c%c%c",HeatTime,HeatInterval);
Note the '%c', not %u. The former sends the single ASCII character, the latter the sequence of characters representing the number in decimal (not what is needed).
You are currently sending ASCII '7', and also the character 7, which is why it doesn't work....
