kmp84
main oscillator problem |
Posted: Sun Jan 08, 2012 9:04 am |
Hi all!
I'm watching that main oscillator on my PIC18F2525 stop work when I touch
osc pins (That is Normal), but when I remove disturbance it's never start normal until power-off and power-on device!
And I've devices that may be have this problem with disturbance coming over power.
My compiler ver. 4.104 |
SherpaDoug
Posted: Sun Jan 08, 2012 10:24 am |
Considering the great effect a 20pF or 27pF capacitor has on the PIC crystal wouldn't you expect having a great big human attached to it would cause a major disturbance?
On the other hand ;-) the fact that it does not restart when you remove your hand may indicate your circuit is marginal. Is the crystal the right type specified by the PIC datasheet? Do you have the right capacitors as specified by the CRYSTAL datasheet? If it is a very small crystal is it being overpowered? Have you compensated for the stray capacitance of any breadboard you may be using? Is the PIC VSS/VDD well bypassed? Are the crystal and loading caps close to the PIC pins? Are there any noisy signal lines passing nearby? _________________ The search for better is endless. Instead simply find very good and get the job done. |
kmp84
Posted: Sun Jan 08, 2012 11:23 am |
Hi "SherpaDoug"!
For Answer of your questions:
I've read datasheet for PIC18f2525 and observ them.
1.crystal -ok
2.Cap 2x20pf closer to OSC pins and GND
3.have 100nf between vcc pin and GND
and e.t.c....
I've make some comparison:
1.With same oscillator circuit and PIC16F628A-Oscillator start normal after disturbance.
2.I've tested couple 8050 devices all of them oscillator work more stable.. |
SherpaDoug
Posted: Sun Jan 08, 2012 11:58 am |
It looks like you have all the usual suspects covered. I am not familiar with the PIC18 series, but I expect their oscillators to be just like the PIC16 series. My only other suggestion would be to try another crystal. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Sun Jan 08, 2012 12:11 pm |
You'd normally say that failure to restart, is a sign of the crystal circuit being overloaded. Too much capacitance?. Though the capacitors sound reasonable, how is the circuit actually built round the oscillator pins?. PCB?. Breadboard?. Wires?. Do you have a ground plane?. If so, is it relieved round the crystal pins?. Have you tried a second chip?. Do you have a spec for the crystal (are you sure it is a parallel resonant type - series resonant ones will often give problems like this with the PIC oscillator).
kmp84
Posted: Sun Jan 08, 2012 3:28 pm |
Unfortunately, link doesn't work.
Yes, the watchdog can restart, or on most modern chips, if you set the FSCM fuse, the chip can switch automatically to the internal oscillator.
Latter chips drive the crystal less hard than older units, which tended to need a series resistor to avoid overdrive problems. If the gain of the crystal is low, might give problems.
However, are you sure your fuses are set right?. For example running a crystal at 8MHz, and selecting the XT fuse, will give a circuit that may well work, but will be underdriving the crystal....
Posted: Sun Jan 08, 2012 3:32 pm |
Working down from the sites main entry gets to the .pdf
What frequency are you running?. Do you know what load capacitance the one you have is rated for (the pdf, is for four different ratings....).
Have you tried with a series resistor?. You may actually be overdriving this type.
kmp84
Posted: Sun Jan 08, 2012 4:55 pm |
Code: | #include <18F2525.h>
#device HIGH_INTS=TRUE
#build (nosleep)
#fuses HS,PROTECT,NOLVP,PUT,BROWNOUT,NOMCLR
#use delay(clock=11059200)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,errors,STREAM=rs_485)
#use rs232(baud=9600,rcv=PIN_B0,STREAM=GP_20_1)
#use rs232(baud=9600,rcv=PIN_B1,STREAM=GP_20_2)
When i use "FCMEN"fuse have a problem with serial communication.
Also try use WDT to make General reset, but it's no happen. |
Joined: 01 Jul 2010 Posts: 9163 Location: Greensville,Ontario
Posted: Sun Jan 08, 2012 6:14 pm |
If the 2525 is like the 4550, the INTernal RC has a default of only 1MHz which may explain the problem with serial communications though you don't say what your problem really is.
Also the Internal RC is not the most stable 'clock' as noted in the datasheet and at higher baudrates will give you problems. |
kmp84
Posted: Tue Jan 10, 2012 2:01 am |
The problem was Solved when I stop "FCMEN" fuse, but I don't know why it's default set. |
