Cap touch on 12f1822
Zachr
PostPosted: Fri Jan 06, 2012 11:05 am     Reply with quote
Hi All,
I've been trying to get the cap touch module up and running with 4.121 and having very little success.
The first thing I tried was some slightly modified help file code:
#include <12F1822.h>
#FUSES NOWDT, INTRC_IO, NOMCLR, NOBROWNOUT, NOLVP
#use delay(int=8000000)
#USE TOUCHPAD (THRESHOLD=5, PIN_A0='5')
void main(void){
     char c;
     setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_OFF,0);
     while(1){
           c = TOUCHPAD_GETC();   //will wait until a pin is detected
           output_high(pin_a5);  //flashes an LED
           delay_ms(10);
           output_low(pin_a5);
           delay_ms(10);
No luck. I tried adjusting thresholds, adding calibration, still nothing.
Then I tried setting up the CPM manually and just tried to see if I could get the CPSOUT bit to toggle.
#byte CPSCON1=0x1f
#byte CPSCON0=0x1e
 int1 c;
 #asm movlb 00 #endasm //just to be sure we are using the right bank
 CPSCON0=0x8c;
 CPSCON1=0;
       c=bit_test(CPSCON0,1);
       output_bit(pin_a5,c);  //look at pin on o-scope
Looking at pin_a5 with an oscilloscope, I just see a high signal. Any ideas on what I am missing?
Thanks,
Zach
PostPosted: Fri Jan 06, 2012 1:32 pm     Reply with quote
You are testing the CPSOUT bit. What do you expect that bit to do,
and why ? What is your hardware test circuit ? What stimulus are
you doing to cause the CPSOUT bit to change ?
Zachr
PostPosted: Fri Jan 06, 2012 2:56 pm     Reply with quote
Based on FIGURE 26-1 of the data sheet, it looks like CPSOUT should toggle at a rate proportional to the cap sense oscillator if the module is active. Any sensed capacitance should change the speed of this oscillator. Typically CPSOUT increments either timer0 or timer1 then you use some fixed time reference to sample that timer to detect the delta. Just checking CPSOUT seemed like a good first step...
As for hardware, I just have four pads connected to a0-a3 surrounded by a gnd trace. I've used the cap sense on other PICs with a similar pad layout. Plus an LED on a5. Running at 3.3v.
PostPosted: Fri Jan 06, 2012 4:28 pm     Reply with quote
If you have your existing touchpad working with a different PIC (other
than the 12F1822), and with the same CCS compiler version, then the
.LST files could be compared to look for differences. To see the CCS
touchpad library code, you have to comment out the #nolist statement
in the 12F1822.h file, and re-compile.
Post a list of all the "cap sense" PICs that you have tested with your
touchpad, and you know they work.
Zachr
PostPosted: Fri Jan 06, 2012 4:48 pm     Reply with quote
Just figured it out... My ICD was connected to the circuit when I was testing it. PGD sits on pin a0 and was killing the oscillator. I usually try to avoid sharing pins with the programming lines, but with only 6 i/o it's almost unavoidable.
Thanks for you help,
Zach
