The code "value = input_x()" could read an entire Byte from 8 pins. But, how to read just 4 pins in the same way of the input_x() command?
I think is easy with input(PIN_X) command, but is there another way?
thank
n-squared
Posted: Fri Jan 06, 2012 12:25 am
There is no way of reading a nibble DIRECTLY.
What you can do is input_x() and AND it with a mask:
X = input_b() & 0x0F; / bits 0 to 3
Y = input_b() >> 4; // bits 4 to 7
Z = (input_b() & 0x3C) >> 2; // bits 2 to 5
BR
NN _________________ Every solution has a problem.
Posted: Fri Jan 06, 2012 2:56 am
As an extra comment, look at the 'swap' function in CCS. This uses a single byte command to swap the high and low nibbles in a byte. Much more efficient than four rotations.
eguti
Posted: Fri Jan 06, 2012 8:01 am
Thanks Ttelmah and n-squared. I will try both tips.
