lcd driver comments
sahu77
lcd_driver
PostPosted: Wed Jan 04, 2012 12:29 pm     Reply with quote
what say about this lcd_driver.....
 #define LCD_D4   PIN_C0
 #define LCD_D5   PIN_C1
 #define LCD_D6   PIN_C2
 #define LCD_D7   PIN_C3
 #define LCD_EN     PIN_C4
 #define LCD_RS    PIN_C5
         LCD
void LCD_Init ( void );
void LCD_SetPosition ( unsigned int cX );
void LCD_PutChar ( unsigned int cX );
void LCD_PutCmd ( unsigned int cX );
void LCD_PulseEnable ( void );
void LCD_SetData ( unsigned int cX );
// LCD FUNCTIONS =================================
    LCD_SetData ( 0x00 );
    delay_ms ( 200 );       // wait enough time after Vdd rise
    output_low ( LCD_RS );
    LCD_SetData ( 0x03 );   // init with specific nibbles to start 4-bit mode
    LCD_PulseEnable();
    LCD_PulseEnable();
    LCD_PulseEnable();
    LCD_SetData ( 0x02 );   // set 4-bit interface
    LCD_PulseEnable();      // send dual nibbles hereafter, MSN first
    LCD_PutCmd ( 0x2C );    // function set (all lines, 5x7 characters)
    LCD_PutCmd ( 0x0C );    // display ON, cursor off, no blink
    LCD_PutCmd ( 0x01 );    // clear display
    LCD_PutCmd ( 0x06 );    // entry mode set, increment
    // this subroutine works specifically for 4-bit Port A
    LCD_SetData ( swap ( cX ) | 0x08 );
    LCD_PulseEnable();
    LCD_SetData ( swap ( cX ) );
    LCD_PulseEnable();
    output_high ( LCD_RS );
    LCD_SetData ( swap ( cX ) );     // send high nibble
    LCD_PulseEnable();
    LCD_SetData ( swap ( cX ) );     // send low nibble
    LCD_PulseEnable();
    LCD_PulseEnable();
    LCD_PulseEnable();
    output_high ( LCD_EN );
    delay_us ( 10 );
    output_low ( LCD_EN );
    delay_ms ( 5 );
    output_bit ( LCD_D4, cX & 0x01 );
    output_bit ( LCD_D5, cX & 0x02 );
    output_bit ( LCD_D6, cX & 0x04 );
    output_bit ( LCD_D7, cX & 0x08 );
pl give comments
sahu
PostPosted: Wed Jan 04, 2012 1:39 pm     Reply with quote
1- not sure why you don't use Flex LCD
2- this code ties up port C PIN functions for DIO - yet those c port pins are often used for more productive stuff than LCD driving
3- does it work for you or not?
sahu77
PostPosted: Wed Jan 04, 2012 1:45 pm     Reply with quote
this driver save up to 17% ROM.
sahu
PostPosted: Wed Jan 04, 2012 2:54 pm     Reply with quote
Ok but...
You can save 100% ROM if you use the LCD in 8 bit mode. Yes, it'll cost you 4 more I/O pins but saves you space.
Or you can save 100% ROM if you use a serial LCD module,This will also save you 6 I/O pins but cost you another PIC to make the serial LCD interface( $1 ?).
Like everything else.. there's a tradeoff. It's up to you to decide which is better.
