Storing long string on serial EEPROM
jelodavid
PostPosted: Fri Aug 08, 2008 11:42 pm     Reply with quote
Hello! I'm PIC C newbie programmer. Could you give me an example program on Serial EEPROM (24LC08) that will store long string of text on it then can be retrieve or display on LCD. I'll be using PIC16F876 or PIC16F877 mcu. Many thanks in advance....
PostPosted: Sun Aug 10, 2008 1:39 pm     Reply with quote
Here is a simple program that does those things.
#include <16F877.H>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay (clock=4000000)
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#include "flex_lcd.c"
#define EEPROM_SDA  PIN_C4
#define EEPROM_SCL  PIN_C3
#include <24256.c>
char const line1[]= {"Hello World"};
int8 i;
int8 buffer[17];
// Write "Hello World" to external eeprom chip.
for(i = 0; i < sizeof(line1); i++)
    write_ext_eeprom(i, line1[i]);
// Read characters from the external eeprom chip
// and write them into a RAM buffer.
    buffer[i] = read_ext_eeprom(i);
// Display the message on the LCD.
printf(lcd_putc, buffer);
jelodavid
PostPosted: Mon Aug 11, 2008 6:16 am     Reply with quote
Thanks a lot!Smile
souravkumarkar
received data from pc & write in eeprom
PostPosted: Sat Dec 31, 2011 2:03 pm     Reply with quote
sir,
i m try many time but result is zero .
PostPosted: Sat Dec 31, 2011 2:18 pm     Reply with quote
Do you have the correct value pullup resistors on the I2C lines?
PostPosted: Sat Dec 31, 2011 2:34 pm     Reply with quote
Look at the connections for the 24LC256 eeprom in the PicDem2-Plus manual.
It's in the upper right corner, on page 25:
http://ww1.microchip.com/downloads/en/devicedoc/51275d.pdf
If you connect it the same way on your board, it should work.
incubator
PostPosted: Fri Mar 09, 2012 9:54 pm     Reply with quote
The code has a little mistake, put this on the begining of the main code:
init_ext_eeprom(); // Call before the other functions are used
PostPosted: Sat Mar 10, 2012 9:07 pm     Reply with quote
That routine just consists of these two lines, which set SCL and SDA to
be input pins:
void init_ext_eeprom()
   output_float(EEPROM_SCL);
   output_float(EEPROM_SDA);
The PIC sets all i/o pins to be inputs during power-on reset. So it really
isn't necessary to call that function. It's just doing something that has
already been done anyway by the hardware.
