PIC18F66K22 - Multiple PWMs
MotoDan
PostPosted: Fri Dec 30, 2011 3:45 pm     Reply with quote
Hello All,
I'm considering using a PIC18F66K22 for a new project that will require 8 PWM outputs whose duty cycle can be controlled independently. All PWMs will be operating at the same frequency. According to the datasheet, there are 7 CCP and 3 ECCP PWM outputs. The datasheet also lists the timer choices for each output. What I'm not 100% sure of is whether or not the duty cycle of each output can be unique. I don't have a development board for this family of MCUs, but do have the latest CCS compiler. My sample code compiles fine with 8 PWMs. Has anyone used this many PWMs on this family of devices?
Thanks in advance and Happy New Year!
MotoDan
PostPosted: Fri Dec 30, 2011 5:47 pm     Reply with quote
They all have separate Period registers (CCPRx) so you should be able
to have a different duty cycle for each PWM channel.
You may not be able to have a different frequency for each PWM channel.
The Timer selection registers allow many different assignments of Timer
resources to the PWM modules. But I didn't go through the 18F66K22
data sheet in detail, to see if you can have a unique Timer for each PWM channel.
MotoDan
PostPosted: Fri Dec 30, 2011 5:55 pm     Reply with quote
Thanks PCM for the reply. I plan on running all of the PWMs at the same frequency so it should work out OK.
