keypad button issue
freedom
keypad button issue
PostPosted: Wed Dec 21, 2011 1:36 pm     Reply with quote
hi all
I'm using Flex_KBD driver for keypad.
This driver returns character when any key is pressed and released . but I want to return character when button is pressed , not to wait until the button released.
////                             Flex_KBD.C                            ////
////                  Generic keypad scan driver                       ////
////  kbd_init()   Must be called before any other function.           ////
////  c = kbd_getc(c)  Will return a key value if pressed or /0 if not ////
////                   This function should be called frequently so as ////
////                   not to miss a key press.                        ////
//Keypad connection:
#define col0 PIN_E0
#define col1 PIN_E1
#define col2 PIN_E2
#define row0 PIN_A0
#define row1 PIN_A1
#define row2 PIN_A2
#define row3 PIN_A3
// Keypad layout:
char const KEYS[4][3] = {{'1','2','3'},
                         {'4','5','6'},
                         {'7','8','9'},
                         {'*','0','#'}};
#define KBD_DEBOUNCE_FACTOR 33    // Set this number to apx n/333 where
                                  // n is the number of times you expect
                                  // to call kbd_getc each second
void kbd_init() {
short int ALL_ROWS (void)
   if (input (row0) & input (row1) & input (row2) & input (row3))
      return (0);
      return (1);
char kbd_getc( ) {
   static byte kbd_call_count;
   static short int kbd_down;
   static char last_key;
   static byte col;
   byte kchar;
   byte row;
   kchar='\0';
   if(++kbd_call_count>KBD_DEBOUNCE_FACTOR) {
       switch (col) {
         case 0   : output_low(col0);
               output_high(col1);
               output_high(col2);
         case 1   : output_high(col0);
               output_low(col1);
               output_high(col2);
         case 2   : output_high(col0);
               output_high(col1);
               output_low(col2);
       if(kbd_down) {
         if(!ALL_ROWS()) {
           kbd_down=false;
           kchar=last_key;
           last_key='\0';
       } else {
          if(ALL_ROWS()) {
             if(!input (row0))
               row=0;
             else if(!input (row1))
               row=1;
             else if(!input (row2))
               row=2;
             else if(!input (row3))
               row=3;
             last_key =KEYS[row][col];
             kbd_down = true;
          } else {
             ++col;
             if(col==3)
               col=0;
      kbd_call_count=0;
  return(kchar);
Any tips ? Please
PostPosted: Wed Dec 21, 2011 5:27 pm     Reply with quote
I want to return character when button is pressed, not to wait until the
button is released.
I think these two changes below (in bold) will probably do it:
if(kbd_down) { // This block detects if a key was released.
if(!ALL_ROWS()) {
kbd_down=false;
// kchar=last_key; // Comment out this line
last_key='\0';
} else { // This block detects if a key was pressed.
if(ALL_ROWS()) {
if(!input (row0))
row=0;
row=1;
row=2;
row=3;
kchar=last_key; // Move it to here
kbd_down = true;
} else {
++col;
if(col==3)
col=0;
freedom
PostPosted: Thu Dec 22, 2011 6:29 am     Reply with quote
Thanks PCM
Now its working.
Would you like to explain about KBD_DEBOUNCE_FACTOR 33
PostPosted: Thu Dec 22, 2011 6:16 pm     Reply with quote
That number controls the rate at which the keypad is polled. For a PIC
running at 20 MHz, the keypad is polled at about a 7.2 KHz rate, which
is really much faster than it needs to be.
I found the rate by adding two lines of code at the start of the keypad
polling code, as shown below. This gives a short pulse on the scope
at a 7.2 KHz rate. I also enabled fast_io for PortC and set the TRIS for
pin C0 to be an output pin. This reduces the ASM code for those two
lines to the minimum.
   output_high(PIN_C0);  // *** TESTING
   output_low(PIN_C0);
If I change KBD_DEBOUNCE_FACTOR to 254, then the polling rate goes
down to 1 KHz (with a 20 MHz crystal on the PIC), and so it's being polled
every 1 ms. Of course it still works, and it's still faster than what you
really need.
