How to use brownout ?
karti.m
PostPosted: Wed Dec 21, 2011 4:44 am     Reply with quote
Can anyone explain what is brownout and how to use it?
asmboy
PostPosted: Wed Dec 21, 2011 1:13 pm     Reply with quote
the DATA sheet for the pic explains it....
when the dc voltage falls below the brownout point - the pic shuts off and resets itself only after the supply voltage exceeds the brownout voltage set by default or fuses
ezflyr
PostPosted: Wed Dec 21, 2011 1:24 pm     Reply with quote
And, I'll add that 'brownout' detection is useful to ensure an orderly shutdown of your PIC when the power source goes away. The idea is that the PIC is still operating "normally" at the brownout trip point, and resets cleanly at this point before the voltage falls any lower and the PIC (potentially) starts to act erratically (I/O changes, etc.).
I had a project recently that was interpreting a falling supply voltage as a switch closure (switches are wired to pull an input to Gnd when pressed), and that was triggering some unintended EEPROM writes. The problem was totally solved by enabling brownout detection.
John
