moved compiler to a different machine
cerr
PostPosted: Tue Dec 20, 2011 2:45 pm     Reply with quote
Hi There,
I moved the compiler to a different machine, I simply copied the whole PICC directory over and adjusted the paths in my .mcp project file. MPLAB was fine with that after telling my project where PICC is located on the new machine. However, when I compile my project I get this:
Executing: "C:\Program Files (x86)\PICC\Ccsc.exe" +FH "MCU2.c" +DF +LN +T +A +M +Z +Y=9 +EA  #__18F86K22=TRUE
*** Error 18 "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 1(9,21): File can not be opened
    Not in ";C:\Users\reggler\Documents\REG1.5\MCU2~\18F86K22.h"
    Not in project "C:\Users\reggler\Documents\REG1.5\MCU2~\18F86K22.h"
*** Error 128 "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 3(34,55): A #DEVICE required before this line
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 3: Error #128: A #DEVICE required before this line
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 5: Error #128: A #DEVICE required before this line
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 6: Error #128: A #DEVICE required before this line
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 7: Error #128: A #DEVICE required before this line
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 8: Error #128: A #DEVICE required before this line
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 9: Error #128: A #DEVICE required before this line
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 10: Error #128: A #DEVICE required before this line
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 11: Error #128: A #DEVICE required before this line
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 12: Error #128: A #DEVICE required before this line
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 13: Error #128: A #DEVICE required before this line
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 22: Error #100: USE parameter value is out of range   Not a number: PIN_C6
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 23: Error #100: USE parameter value is out of range   Not a number: PIN_G1
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 24: Error #100: USE parameter value is out of range   Not a number: PIN_C4
*** "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 26: Error #128: A #DEVICE required before this line
      16 Errors,  0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Tue Dec 20 12:38:23 2011
It says *** Error 18 "C:\Users\reggler\Documents\REG1.5\MCU2~\MCU2.h" Line 1(9,21): File can not be opened but i can click on MCU2.h in my project browser and the file opens up just fine. What's going on here? Anyone done this before?
Thank you!
PostPosted: Tue Dec 20, 2011 3:48 pm     Reply with quote
Launch a new _project_ and select the files.
Problem is that the project file contains the locations of the files it wants to find. Unless the entire directory structure on the new machine is the same as on the old one, it'll be telling the compiler to look in the wrong place for the files, and they won't be found.
