pilar
Problem with WHILE |
Posted: Fri Dec 16, 2011 8:52 am |
Hi, someone can tell me what is my mistake!!!, why not leave the conditional (do..while), when any of the two conditions is true ...
but now, just let this conditional only when two conditions are true ...
Code: | #include <18F452.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,NOSTVREN
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, ERRORS)// RS232 Estándar
#define RESETX 0
char Estado = RESETX;
int8 k;
#define Program PIN_B4
while (TRUE) {
k = 1;
Estado = 1;
do{
if (Estado == 1) {
k++;
} while ((input(Program)!=0)||(k < 5));
asmallri
Re: Problem with WHILE |
Posted: Fri Dec 16, 2011 1:37 pm |
pilar wrote: | Hi, someone can tell me what is my mistake!!!, why not leave the conditional (do..while), when any of the two conditions is true ...
#define RESETX 0
int8 k;
while (TRUE) {
k = 1;
Estado = 1;
do{
if (Estado == 1) {
k++;
} while ((input(Program)!=0)||(k < 5)); <<-- *** WRONG LINE, move to the brace above
_________________ Regards, Andrew
Posted: Fri Dec 16, 2011 3:48 pm |
No, it is just awfully laid out, so it _looks_ like it is on the wrong line....
while (TRUE) {
k = 1;
Estado = 1;
do {
if (Estado == 1) {
k++;
However how would you ever know it had left the do...while?. As soon as it leaves, it'll execute the outer while loop, and start again.
Big question though is do you really want to use 'OR'?. The loop will be done, while pin B4 is high _OR_ k is less than 5. So the 'exit condition', is B4 being low _AND_ k>=5.
