Increase Modbus Points
koray_duran
PostPosted: Fri Dec 16, 2011 1:57 am     Reply with quote
I work on modbus in these days, maybe it is very simple question but i couldn't figure out how to increase modbus points. It seems only 8 points per type. I wait your answers.
Here is my code:
#include <18F67J60.h>
#fuses   HS, NOWDT, NOPROTECT, NOFCMEN, PRIMARY, NOETHLED
#use     delay(clock=25M)
#define MODBUS_TYPE                       MODBUS_TYPE_SLAVE
#define MODBUS_SERIAL_RX_BUFFER_SIZE      64
#define MODBUS_SERIAL_BAUD                9600
#define USE_WITH_PC                       1
#define POT                               PIN_F3
#define BUT                               PIN_B0
#define LED                               PIN_B4
#ifndef USE_WITH_PC
#define MODBUS_SERIAL_INT_SOURCE          MODBUS_INT_EXT
#define MODBUS_SERIAL_TX_PIN              PIN_C6   // Data transmit pin
#define MODBUS_SERIAL_RX_PIN              PIN_C7   // Data receive pin
//The following should be defined for RS485 communication
//#define MODBUS_SERIAL_ENABLE_PIN          PIN_B0   // Controls DE pin for RS485
//#define MODBUS_SERIAL_RX_ENABLE           PIN_B0   // Controls RE pin for RS485
#else
#define MODBUS_SERIAL_INT_SOURCE          MODBUS_INT_RDA
#endif
#include "modbus.c"
#define MODBUS_ADDRESS 0x01
/*This function may come in handy for you since MODBUS uses MSB first.*/
int8 swap_bits(int8 c)
   return ((c&1)?128:0)|((c&2)?64:0)|((c&4)?32:0)|((c&8)?16:0)|((c&16)?8:0)
          |((c&32)?4:0)|((c&64)?2:0)|((c&128)?1:0);
   int8  coils = 0b00000101;
   int8  inputs = 0b00001001;
   int16 hold_regs[40] = {
   0x1100,0x2200,0x3300,0x4400,0x5500,0x6600,0x7700,0x8800,
   int16 input_regs[40] = {
   int16 event_count = 0;
   modbus_init();
      while(!modbus_kbhit());
      //check address against our address, 0 is broadcast
      if((modbus_rx.address == MODBUS_ADDRESS) || modbus_rx.address == 0)
         switch(modbus_rx.func)
            case FUNC_READ_COILS:    //read coils
            case FUNC_READ_DISCRETE_INPUT:    //read inputs
               if(modbus_rx.data[0] || modbus_rx.data[2] ||
                  modbus_rx.data[1] >= 8 || modbus_rx.data[3]+modbus_rx.data[1] > 8)
                  modbus_exception_rsp(MODBUS_ADDRESS,modbus_rx.func,ILLEGAL_DATA_ADDRESS);
                  int8 data;
                  if(modbus_rx.func == FUNC_READ_COILS)
                     data = coils>>(modbus_rx.data[1]);      //move to the starting coil
                     data = inputs>>(modbus_rx.data[1]);      //move to the starting input
                  data = data & (0xFF>>(8-modbus_rx.data[3]));  //0 out values after quantity
                     modbus_read_discrete_input_rsp(MODBUS_ADDRESS, 0x01, &data);
                  event_count++;
            case FUNC_READ_HOLDING_REGISTERS:
            case FUNC_READ_INPUT_REGISTERS:
                  if(modbus_rx.func == FUNC_READ_HOLDING_REGISTERS)
                     modbus_read_holding_registers_rsp(MODBUS_ADDRESS,(modbus_rx.data[3]*2),hold_regs+modbus_rx.data[1]);
                     modbus_read_input_registers_rsp(MODBUS_ADDRESS,(modbus_rx.data[3]*2),input_regs+modbus_rx.data[1]);
                  event_count++;
            case FUNC_WRITE_SINGLE_COIL:      //write coil
               if(modbus_rx.data[0] || modbus_rx.data[3] || modbus_rx.data[1] > 8)
               else if(modbus_rx.data[2] != 0xFF && modbus_rx.data[2] != 0x00)
                  modbus_exception_rsp(MODBUS_ADDRESS,modbus_rx.func,ILLEGAL_DATA_VALUE);
                  //coils are stored msb->lsb so we must use 7-address
                  if(modbus_rx.data[2] == 0xFF)
                     bit_set(coils,7-modbus_rx.data[1]);
                     bit_clear(coils,7-modbus_rx.data[1]);
                  modbus_write_single_coil_rsp(MODBUS_ADDRESS,modbus_rx.data[1],((int16)(modbus_rx.data[2]))<<8);
                  event_count++;
            case FUNC_WRITE_SINGLE_REGISTER:
               if(modbus_rx.data[0] || modbus_rx.data[1] >= 8)
                  //the registers are stored in little endian format
                  hold_regs[modbus_rx.data[1]] = make16(modbus_rx.data[3],modbus_rx.data[2]);
                  modbus_write_single_register_rsp(MODBUS_ADDRESS,
                               make16(modbus_rx.data[0],modbus_rx.data[1]),
                               make16(modbus_rx.data[2],modbus_rx.data[3]));
            case FUNC_WRITE_MULTIPLE_COILS:
                  int i,j;
                  modbus_rx.data[5] = swap_bits(modbus_rx.data[5]);
                  for(i=modbus_rx.data[1],j=0; i < modbus_rx.data[1]+modbus_rx.data[3]; ++i,++j)
                     if(bit_test(modbus_rx.data[5],j))
                        bit_set(coils,7-i);
                        bit_clear(coils,7-i);
                  modbus_write_multiple_coils_rsp(MODBUS_ADDRESS,
                  event_count++;
            case FUNC_WRITE_MULTIPLE_REGISTERS:
                  int i,j;
                  for(i=0,j=5; i < modbus_rx.data[4]/2; ++i,j+=2)
                     hold_regs[i] = make16(modbus_rx.data[j+1],modbus_rx.data[j]);
                  modbus_write_multiple_registers_rsp(MODBUS_ADDRESS,
                  event_count++;
            default:    //We don't support the function, so return exception
               modbus_exception_rsp(MODBUS_ADDRESS,modbus_rx.func,ILLEGAL_FUNCTION);
RF_Developer
PostPosted: Fri Dec 16, 2011 3:25 am     Reply with quote
Read the code. All you need to know is there.
Try walking through it. Work out line by line what the code does, imagining what will happen with various different values. Try it with different MODBUS addresses.
Here's a hint: you are wondering why it only allows you 8 of each type of item. Try searching for the number 8 in the code, or perhaps 7. Where does it appear? Why does it appear where it does? What would happen if you changed it?
Walkthroughs are one of the the simplest and effective code reading and checking techniques. Use them to improve your understanding of C (and of other code). It will improve the code you write too.
RF Developer
FvM
PostPosted: Fri Dec 16, 2011 5:46 am     Reply with quote
As an additional suggestion, read the MODBUS application protocol specification from modbus.org to understand what the software does.
Sid2286
PostPosted: Sat Jan 07, 2012 8:58 pm     Reply with quote
Hi everyone,
I was successful in implement modbus protocol using function 3 and function 4, i.e holding and input registers. However I'm finding it tricky to implement function 10, i.e write multiple register. Since the input here is 2 bytes I don't know how to work on it.
                  int i,j;
                  event_count++;
How do I proceed ? I want to write data on over this function. Please help.
Sid2286
problem not yet sorted
PostPosted: Tue Jan 10, 2012 2:16 am     Reply with quote
I tried using multiple registers for writing, and the response showed ok.
However, I've only been able to write a single register from the multiple register case.
I did the following modification in the code.
hold_regs[modbus_rx.data[1]] = make16(modbus_rx.data[j],modbus_rx.data[j+1]);
Please help. How should I proceed?
Eagerly awaiting for your response.
SId
FvM
PostPosted: Tue Jan 10, 2012 3:59 am     Reply with quote
In contrast to the reasonable code in your previous post, your writing all data to a single holding register. Why?
Sid2286
PostPosted: Tue Jan 10, 2012 10:47 pm     Reply with quote
I'm bit confused while figuring out the logic. I don't understand the 'i' variable, it should get the data and and add to the holding register and increment. But that is not happening. Thats when I used
which at least adds the data into an array of holding register. But since 'modbus_rx.data[1]' is one its suppose to add only one value.
Later I tried with
for(i=0, j=5; i < modbus_rx.data[4]/2; ++i, j+=2)  //changed i=0
                        /*hold_regs[i+8]*/hold_regs[modbus_rx.data[i+8]] = make16(modbus_rx.data[j], modbus_rx.data[j+1]); // j=j+1 and j+1 =j
                        //hold_regs[modbus_rx.data[1]] = make16(modbus_rx.data[2], modbus_rx.data[3]);
event_count++;
ax[0]=hold_regs[8];
ay[0]=hold_regs[9];
ax[1]=hold_regs[10];
ay[1]=hold_regs[11];
ax[2]=hold_regs[12];
ay[2]=hold_regs[13];
ax[3]=hold_regs[14];
ay[3]=hold_regs[15];
ax[4]=hold_regs[16];
ay[4]=hold_regs[17];
ax[5]=hold_regs[18];
ay[5]=hold_regs[19];
ax[6]=hold_regs[20];
ay[6]=hold_regs[21];
ax[7]=hold_regs[22];
ay[7]=hold_regs[23];
But again its not working Sad Please help. I'm trying really hard.
Sid
Sid2286
PostPosted: Wed Jan 11, 2012 1:52 am     Reply with quote
Sorry for the trouble. problem is sorted out of writing on multiple register on modbus.
But now i cant write on eeprom in that case.
 for(i=0,j=5; i < modbus_rx.data[4]/2; ++i,j+=2)  //changed i=0
                        hold_regs[i] = make16(modbus_rx.data[j],modbus_rx.data[j+1]); // j=j+1 and j+1 =j
                                event_count++;
                                ax[0]=hold_regs[8];
                                ay[0]=hold_regs[9];
                                skipFlag[0]=hold_regs[24];
                                skipFlag[1]=hold_regs[25];
                                skipFlag[2]=hold_regs[26];
                                skipFlag[3]=hold_regs[27];
                                skipFlag[4]=hold_regs[28];
                                skipFlag[5]=hold_regs[29];
                                skipFlag[6]=hold_regs[30];
                                skipFlag[7]=hold_regs[31];
                                rs_cpu=hold_regs[32];
                                delay_ms(5);
                                if(rs_cpu==0)
                                    reset_cpu();
                                int l2=0;
                                for( l2=0;l2<8;l2++)
                                   write_eeprom(7+offset,alarmflag[l2]);
                                   //delay_ms(5);
                                   temEE=ax[l2]/256;
                                   write_eeprom(8+offset,temEE);
                                   //delay_ms(5);
                                   temEE=ax[l2]%256;
                                   write_eeprom(9+offset,temEE);
                                   //delay_ms(5);
                                   temEE=ay[l2]/256;
                                   write_eeprom(10+offset,temEE);
                                   //delay_ms(5);
                                   temEE=ay[l2]%256;
                                   write_eeprom(11+offset,temEE);
                                   //delay_ms(5);
                                   write_eeprom(16+offset,skipFlag[l2]);
                                   //delay_ms(5);  */
its not getting written on EEPROM.
but when i do the same outside the function it does get written on the EEPROM
