#INT_TIMER1
sahu77
#INT_TIMER1
PostPosted: Mon Oct 31, 2011 12:49 pm     Reply with quote
I'm doing right ?
  Timer1 Interrupt, executed every 10 ms
#INT_TIMER1
void TIMER1_isr(void)
   // Increment time_elasped to keep track of ms
   time_elasped++;
   // Increment seconds variable if 1000 ms have passed
   if (time_elasped == 100)  // led blink frequency @ 1000 ms
        seconds++;
        BlinkLED_flag=~BlinkLED_flag;
         time_elasped = 0;
   // On start up, blink LED for 3 mins
   //led1 blink mains normal, led1 blink & Reads ADC
   // both are work in same time. not one by one.
   //if led blink duration complete then it no blink agen.
   //Has three mins passed?
    if (seconds > STARTUP_SEC)
       BlinkMains_flag=1;
       //output_high(RL5);
   //Reset Timer 1
   set_timer1(60545);
   clear_interrupt(INT_TIMER1);
set_timer1(60545);
is right ?
sahu
mtsoule
PostPosted: Mon Oct 31, 2011 2:22 pm     Reply with quote
Looks right to me, just make sure you enable your interrupts.
sahu77
PostPosted: Tue Dec 13, 2011 1:12 pm     Reply with quote
what is this 60545?
sahu
Douglas Kennedy
PostPosted: Tue Dec 13, 2011 7:08 pm     Reply with quote
!6 bit timers count up. Now if the timer is set to a value EX 60545 then it counts up from that value. This allows for fine tuning in addition to scalers that are limited to a few powers of two.
starter
PostPosted: Wed Dec 14, 2011 2:14 pm     Reply with quote
Timer1 is 16bit and it overflow is 65535 if you set_timer1(0) and if you use set_timer1(60545) ticks made to reach 65535 is given by 65535- 60545=4990, now to check what is the clock defined. If clock defined is 48MHz (usually for USB) then it is previously divided by 4 giving 12MHz if no prescaler value defined. Now take 4990/12MHz and this is the time timer1 takes to overflow for this case it is 415.83us so, everytime timer interrupt occurs at this time. Also, check the link below:
http://www.ccsinfo.com/forum/viewtopic.php?t=22467
sahu77
PostPosted: Thu Dec 15, 2011 4:38 am     Reply with quote
I am using 4 MHZ internal osc. PIC 16F676
sahu
PostPosted: Thu Dec 15, 2011 8:49 am     Reply with quote
Be aware that internal oscillators are NOT great 'time keepers'...
sahu77
Re: #INT_TIMER1
PostPosted: Sun Jan 08, 2012 10:17 am     Reply with quote
#INT_TIMER1
   time_elasped++;
        seconds++;
         time_elasped = 0;
       BlinkMains_flag=1;
       //output_high(RL5);
   //Reset Timer 1
   set_timer1(60545);
how can use it as countdown timer display on 16*2 lcd .
xtal 4 MHz @16f72
sahu
PostPosted: Sun Jan 08, 2012 6:17 pm     Reply with quote
I suggest you look at the software RTC that's in the code library.
it works, easy to understand, and is easy to modify for your use...
