is this too crazy compiler behavior??
asmboy
PostPosted: Sat Dec 10, 2011 5:17 pm     Reply with quote
Been using ver 4.085 very happily - mostly with 18F parts - since 4.085 was released.
Just moved a simple timer0 , polled handler - to count down 10msec increments - that works like a charm on many 18f parts like 18f4620 4520 2423 452 etc etc etc - with timer0 in 8 bit mode -
Today I tried to use the same code on an 18f887 - but found that
--woundtix - on the f887 caused a near instant exit!
the routine exited instantly in under 1 sec when told to use a 10 sec delay.
I traced my problem to decrementing a declared
unsigned int16 woundtix - where - in each case using 8 mhz int clock- no PLL or fuse funnies etc . and polled from main() -
Check out this LST extract - where I was forced to switch to using
the second method of decrementing to keep the code working properly
on the 16F part .. bizarre - or is it me ??
.................... void Time0Up(void) {
....................       if (  T0IF  )  {          //   [IF]  timer rollover flag set
01EC:  BTFSS  0B.2
01ED:  GOTO   203
....................          set_timer0(100);   // [THEN] start next round of 10 msec
01EE:  MOVLW  64
01EF:  MOVWF  01
....................          T0IF = 0;         // clear t0if
01F0:  BCF    0B.2
....................          if ( woundtix ) --woundtix; //  BAD --unsigned INT16
01F1:  MOVF   31,W      // THIS attempt to decrement  caused VERY
01F2:  IORWF  32,W     // rapid reduction of unsigned int16 woundtix
01F3:  BTFSC  03.2       // aND WAS replaced by the following method
01F4:  GOTO   1F9       // which gives the proper result
01F5:  MOVF   31,W    // put low byte in workreg - test zero
01F6:  BTFSC  03.2     //  if !=zero skip the dec  upper byte
01F7:  DECF   32,F    //    what abt carry ??
01F8:  DECF   31,F    //  ????
....................          if ( woundtix ) WoundTix=woundtix-1; // works
01F9:  MOVF   31,W    // as intended
01FA:  IORWF  32,W
01FB:  BTFSC  03.2
01FC:  GOTO   203
01FD:  MOVLW  01
01FE:  SUBWF  31,F
01FF:  MOVLW  00
0200:  BTFSS  03.0
0201:  MOVLW  01
0202:  SUBWF  32,F
....................        // count  A 10ms event stream as well
....................        // end of line  checking for timing all done
....................       if ( 0 == WoundTix ) {   // do stuff
PostPosted: Sun Dec 11, 2011 8:15 am     Reply with quote
16F887?
what abt carry ??
The skip before is the carry.
The code is working correctly so far.
asmboy
PostPosted: Sun Dec 11, 2011 9:46 am     Reply with quote
all i know is that the FIRST version - using --woundtix;
does NOT "count right" - based on a stopwatch test -
and ONLY when compiled for a 16f887 !!!
same code - same everything - works perfectly on an 18F4620 --
i was only porting the code from the 18f to reduce the cost of production on a fully tested and working prodcut.
anyway - the second one DOES perform properly -- on both PICS-
it was only after a lot of head scratching that i resorted to:
var=var-1; syntax - and was puzzled as heck as to what was going on.
i only posted because i was shocked to find very basic code that was "broken" like that.
PostPosted: Sun Dec 11, 2011 3:01 pm     Reply with quote
I didn't find a problem.
First I made the program below in MPLAB. I put breakpoints on the line
that sets woundtix to 0xFFFF and on the while(1) line at the end. I enabled
the MPLAB stopwatch function. I ran the program until it stopped at the
first breakpoint in MPLAB simulator and then I zeroed the Stopwatch.
Then I ran it to the last breakpoint. I got a stopwatch duration of
170.4924 ms for the loop code:
#include <16F887.h>
#fuses HS, NOWDT
#use delay(clock=20M)
int16 woundtix;
woundtix = 0xFFFF;
while(woundtix != 1)
      if(woundtix) --woundtix;
Then I edited the above program and replaced the loop code with this:
      if(woundtix) woundtix = woundtix-1;
This time I got 196.706 ms. It's a bit longer than the first program, but
not enormously longer. But the longer execution time is be expected
because it takes a couple more ASM instructions to do the subtraction,
compared to the decrement.
These tests were done with vs. 4.085. So I didn't see a problem.
PostPosted: Sun Dec 11, 2011 4:04 pm     Reply with quote
My point is, I don't see a problem with the code shown in your post.
if(woundtix) --woundtix compiles to identical assembly level code in recent CCS C versions. Nevertheless,
to make the problem understandable, please post a complete compilable example that allows to reproduce it.
There may be something that doesn't reveal in the shown example.
asmboy
PostPosted: Sun Dec 11, 2011 8:06 pm     Reply with quote
found it after more head scratching
there are various #includes - involved here
i was fooling myself with a fixed #bit T0IF definition that was correct for 18F family - located earlier in the program - but no so hot for 18F cuz it reads as an address beyond 16F reg space - as a '1' no matter how often i tried to clear it .....so T0IF was ALWAYS set etc etc etc
when i changed what i thought was the faulty math - i had also at the same time - switched to the include file i had used with a much older 16F project -- that happened to use the correct register bit address for T0IF -
it was ending early because T0IF would not stay clear - no ta math bug ;-))
i am happy to report that both means of decrementing do work after all.
mea culpa
andrewg
PostPosted: Sun Dec 11, 2011 9:25 pm     Reply with quote
Is that your only use for T0IF? If so, then:
clear_interrupt(INT_TIMER0);
would be the portable way of doing that.
Andrew
