reptile404
Keypad 4x3 problem |
Posted: Fri Dec 09, 2011 3:40 pm |
Hello!
I dont know why this code does not work ?
I use pic 16f877a +keypad (4x3)+lcd.
Nothing displayed on LCD. I use port B for LCD and Port D for Keypad.
#include "keypad2.h"
#include <KBD.C>
# use fast_io (D)
# use fast_io (b)
#define LCD_ENABLE_PIN PIN_B0
#define LCD_RS_PIN PIN_B1
#define LCD_RW_PIN PIN_B2
#define LCD_TYPE 1
#include <lcd.c>
char c;
kbd_init();
lcd_putc("\fwaiting...\n");
// port_b_pullups(TRUE);
//setup_adc_ports(AN0);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
//setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
// enable_interrupts(INT_TIMER0);
// enable_interrupts(GLOBAL);
// TODO: USER CODE!!
c=kbd_getc();
if(c!=0)
if(c=='*')
lcd_putc('\f');
lcd_gotoxy(1,2);
// printf(lcd_putc,"%c",c);
output_c(c);
the compiler version is 4.032 _________________ REPTILE404
55AA55AA55 |
Joined: 01 Jul 2010 Posts: 9199 Location: Greensville,Ontario
Posted: Fri Dec 09, 2011 4:00 pm |
You should say which PIC you're using as well as the hookup to the KPD,pullups,pulldowns,etc.
Does the LCD work without KPD OK ?
What's in the KPd header file ? |
reptile404
Posted: Sat Dec 10, 2011 7:29 am |
yes Lcd works pretty good , but keypad no
the KBD header is :
//// KBDD.C ////
//// Generic keypad scan driver ////
//// kbd_init() Must be called before any other function. ////
//// c = kbd_getc(c) Will return a key value if pressed or /0 if not ////
//// This function should be called frequently so as ////
//// not to miss a key press. ////
//// (C) Copyright 1996,2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
////////////////// The following defines the keypad layout on port D
// Un-comment the following define to use port B
//#define use_portb_kbd TRUE
// Make sure the port used has pull-up resistors (or the LCD) on
// the column pins
#if defined(__PCH__)
#if defined use_portb_kbd
#byte kbd = 0xF81 // This puts the entire structure
#else
#byte kbd = 0xF83 // This puts the entire structure
#endif
#else
#byte kbd = 6 // on to port B (at address 6)
#else
#byte kbd = 8 // on to port D (at address 8)
#endif
#endif
#define set_tris_kbd(x) set_tris_b(x)
#else
#define set_tris_kbd(x) set_tris_d(x)
#endif
//Keypad connection: (for example column 0 is B2)
// Bx:
#ifdef blue_keypad ///////////////////////////////////// For the blue keypad
#define COL0 (1 << 2)
#define COL1 (1 << 3)
#define COL2 (1 << 6)
#define ROW0 (1 << 4)
#define ROW1 (1 << 7)
#define ROW2 (1 << 1)
#define ROW3 (1 << 5)
#else ////////////////////////////////////////////////// For the black keypad
#define COL0 (1 << 5)
#define COL1 (1 << 6)
#define COL2 (1 << 7)
#define ROW0 (1 << 1)
#define ROW1 (1 << 2)
#define ROW2 (1 << 3)
#define ROW3 (1 << 4)
#endif
#define ALL_ROWS (ROW0|ROW1|ROW2|ROW3)
#define ALL_PINS (ALL_ROWS|COL0|COL1|COL2)
// Keypad layout:
char const KEYS[4][3] = {{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}};
#define KBD_DEBOUNCE_FACTOR 33 // Set this number to apx n/333 where
// n is the number of times you expect
// to call kbd_getc each second
void kbd_init() {
char kbd_getc( ) {
static BYTE kbd_call_count;
static short int kbd_down;
static char last_key;
static BYTE col;
BYTE kchar;
BYTE row;
kchar='\0';
if(++kbd_call_count>KBD_DEBOUNCE_FACTOR) {
switch (col) {
case 0 : set_tris_kbd(ALL_PINS&~COL0);
kbd=~COL0&ALL_PINS;
case 1 : set_tris_kbd(ALL_PINS&~COL1);
kbd=~COL1&ALL_PINS;
case 2 : set_tris_kbd(ALL_PINS&~COL2);
kbd=~COL2&ALL_PINS;
if(kbd_down) {
if((kbd & (ALL_ROWS))==(ALL_ROWS)) {
kbd_down=FALSE;
kchar=last_key;
last_key='\0';
} else {
if((kbd & (ALL_ROWS))!=(ALL_ROWS)) {
if((kbd & ROW0)==0)
row=0;
else if((kbd & ROW1)==0)
row=1;
else if((kbd & ROW2)==0)
row=2;
else if((kbd & ROW3)==0)
row=3;
last_key =KEYS[row][col];
kbd_down = TRUE;
} else {
++col;
if(col==3)
col=0;
kbd_call_count=0;
set_tris_kbd(ALL_PINS);
return(kchar);
} _________________ REPTILE404
55AA55AA55 |
Posted: Sat Dec 10, 2011 7:55 am |
hmm...
#include <KBD.C>
1) You've shown us the KBDD.C driver but use KBD.C
2) Do not know what's in keypad2.h
3) post the schematic of the project
4) are you're KPDs rows and columns correct? Pullup values ? |
reptile404
Posted: Sat Dec 10, 2011 8:24 am |
Well, you told me that I've shown you KBDD.c not KBD.c.
I used the driver that comes with the compiler which is kbd.c
and I've shown to you, here's the header (keypad.h):
#include <16F877A.h>
#device adc=8
#FUSES XT //Crystal osc <= 4mhz
#FUSES WRT_50% //Lower half of Program Memory is Write Protected
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
and here's the schematic :
55AA55AA55 |
Posted: Sat Dec 10, 2011 9:04 am |
Since the schematic is from ISIS, have to ask are you using the simulator or using real hardware ?
Have you confirmed with a meter or scope that the KPD wiring is correct ?
Looks like you should have a 'black ' keypad configuration ?
Your ISIS schematic is 'fuzzy' and small so I can't confirm the row/col/pin assignments.
Unless you have a 'black kpd' from CCS there's a chance yours is not configured the same way. |
Posted: Sun Dec 11, 2011 5:02 pm |
Your keypad connections are incorrect, to both the PIC and the pullups.
Change your schematic to this:
PIC
pin -- Keypad pin
D0 -- N/C
D1 -- Row 0
D2 -- Row 1
D3 -- Row 2
D4 -- Row 3
D5 -- Col 0
D6 -- Col 1
D7 -- Col 2
Move the pullups so they are on the Row pins (not the column pins).
Each row pin must have a pullup.
The list of connections given above comes directly from here:
#else /////////////// For the black keypad
