C debugging
electronx.x.2
View user's profile Send private message AIM Address MSN Messenger
C debugging
PostPosted: Thu Dec 08, 2011 10:11 pm     Reply with quote
Hello, I'm facing a problem here. I want the debugger to compile in C. I mean the single step, cursor, step over, these should debug in C, not in assembly. I am using ccs 4.114 with icd-u64.
Is there any other option I have, to see single-step line by line in C, not in assembly ? Plz help.
TMLtech
PostPosted: Fri Dec 09, 2011 1:37 am     Reply with quote
I use CCSC mplab plugin and debugging in mplab IDE. This combination works very well.
electronx.x.2
PostPosted: Fri Dec 09, 2011 3:19 am     Reply with quote
hmmm, let me try thnx
PostPosted: Fri Dec 09, 2011 3:24 am     Reply with quote
Normally in MPLAB, if you have the assembler window as the active window, it steps in assembler instructions, while if you have the source code window as the active window it steps in C lines.
Make sure you have the code window as the highlighted one when you step.
Best Wsihes
