Posted: Fri Dec 09, 2011 4:12 am |
If you have a crystal at 12M, and the CPU running at 12M, then the PLL has to be off.....
What has happened is that CCS have tightened things up.
So if you have the CPU running at 12MHz, you either have to say just this (clock=12M), and specify the PLL fuse yourself, or you have to specify both the clock frequency (clock=xxx), _and_ the crystal _frequency_ (not just crystal, but crystal=yyy), which then enables the PLL if needed to get that combination.
