Baffled with this problem
snock
PostPosted: Thu Dec 08, 2011 10:08 am     Reply with quote
The following code does not set the values to the the data structure zone. MAXZONE is equal to 6. The i (int8) variable is printed to the LCD and works correctly. zone[0].off_t when printed shows uninitialized data. If I use zone[0].off_t in the loop it works. Looks like a CCS bug but I wanted to confirm it. I'm running 4.127.
   if(time_t.hour==0) { // Load default or use saved?
      lcd_gotoxy(2,2);
      lcd_putc("LOADING DEFAULTS");
      for(i=0; i<MAXZONE; i++) {
         printf(lcd_putc,"%u ",i);
         zone[i].off_t=10;
         zone[i].on_t=5;
         zone[i].pk_off_t=5;
         zone[i].flt_flsh_t=2;
         zone[i].flt_flsh_c=1;
         zone[i].fld_flsh_t=3;
         zone[i].fld_flsh_c=5;
         zone[i].flt_flsh_cyc=0;
         zone[i].fld_flsh_cyc=0;
         zone[i].drain_t=3;
      //save_param(); // Save zone settings to flash
PostPosted: Thu Dec 08, 2011 10:33 am     Reply with quote
It sounds as if you are using a debugger of some sort?.
How is zone declared?.
A variable has a value once declared, even if nothing has been written to it. Normally all binary 1's. The message suggests the debugger doesn't understand the code that CCS generates to access an offset variable. If you use a fixed index, a direct access to memory will be performed (which the debugger presumably understands), but using a variable it'll be done using indirect access.
Try printing the variables with printf, rather than the debugger.
snock
PostPosted: Thu Dec 08, 2011 12:10 pm     Reply with quote
I should have said so, but I am indeed using printf (to the LCD) to print out the data. I am not using a debugger but rather loading the code with the ICD-U64 to a PIC24FJ64GB106. I don't use the ICD for anything other than program loading at this point. I also have tried using a literal, ie zone[0].off_t, rather than the i variable. It works using the literal but of course I would like to use the for loop to stuff in the default data. The i variable is not used globally either not to mention I tried using different variable names with no success.
PostPosted: Thu Dec 08, 2011 1:29 pm     Reply with quote
OK.
Still the question of how zone is declared, and where?.
snock
PostPosted: Thu Dec 08, 2011 1:37 pm     Reply with quote
It's declared before main() so it's global.
// * ZONE CONTROL STRUCTURE ****************************************************
struct z_type {
   unsigned int32 dose_c;        // Dose counter for zone
   unsigned int32 on_t;          // On time (minutes, def=5 min)
   unsigned int32 off_t;         // Off time (minutes, def=115 min)
   unsigned int32 pk_off_t;      // Peak off time (minutes, def=115 min)
   unsigned int32 drain_t;       // Drain timer to keep zone / field valve open
   unsigned int32 flt_flsh_t;    // Filter flush time (seconds, def=20 sec)
   unsigned int32 flt_flsh_c;    // Filter flush counter (def=1 cycle)
   unsigned int32 flt_flsh_cyc;  // Cycle counter for flush valve
   unsigned int32 fld_flsh_t;    // Field flush time (minutes, def=1 min)
   unsigned int32 fld_flsh_c;    // Field flush counter (def=20 cycles)
   unsigned int32 fld_flsh_cyc;  // Cycle counter for field valve
   unsigned int8 num_zone;
} zone[6];
PostPosted: Thu Dec 08, 2011 1:49 pm     Reply with quote
As with every problem of this kind, can you reproduce it in a compact example application? If so, please show it.
andrewg
PostPosted: Thu Dec 08, 2011 9:25 pm     Reply with quote
While I think the code as given should work (as in, I don't see anything wrong with it), I'd still do it a little differently:
       lcd_gotoxy(2,2);
       zone[0].off_t=10;
       zone[0].on_t=5;
       zone[0].pk_off_t=5;
       zone[0].flt_flsh_t=2;
       zone[0].flt_flsh_c=1;
       zone[0].fld_flsh_t=3;
       zone[0].fld_flsh_c=5;
       zone[0].flt_flsh_cyc=0;
       zone[0].fld_flsh_cyc=0;
       zone[0].drain_t=3;
       for(i=1; i<MAXZONE; i++) {
          zone[i]=zone[0];
That should still work, but should be a lot smaller since the compiler isn't calculating lots of zone[i].
Andrew
RF_Developer
PostPosted: Fri Dec 09, 2011 3:27 am     Reply with quote
I don't know if this is the cause, but there are/have been some issues with structures and arrays of structures that are greater than 256 bytes long.
In your case a single instance of a structure is 45 bytes: 11 int32s @ 4 bytes each plus an int8. These may be aligned to 4 byte boundaries, or possibly 2 byte on a PIC24, so effectively in an array of them they may look like 48/46 bytes each: 45 bytes with 3 or 1 padding bytes. That's more likely on other processors, such as ARMs, and certainly on PCs. Your array is 6 of these, so its either 270 bytes or 288 if its padded. Either way one of the structures crosses a 256 byte boundary. The trouble may be related to indexing finding the offset of a structure correctly, but then individual members are not correctly addressed due to indexing limitations... or something.
I detect a hint of a "coding standard" in your code. One that assumes all variables will be 32 bit unless otherwise stated. Do all these variable really NEED to be 32 bit, or is it just a "standard"? If not, then careful sizing may solve the problem, and will certainly reduce RAM requirements and improve performance if nothing else.
You are also using descriptive suffixes which confused me. I see time_t and automatically assume it means time type, as is the conventional. Reading on, I see it must mean its a variable holding a time, _c meaning holding a count and so on. I am sure you know what it means, its just that it clashes with other more widely used conventions, which makes your code difficult to read. This tends to make me think you are working to some style guide that proscribes this stuff, and maybe the int 32s too....
RF Developer.
