waqas_shafique
| Measuring Pulse low time |
Posted: Sat Dec 03, 2011 4:01 am |
Hi
I'm using CCS C's example file to measure pulse width( high time). I want to change this example program to measure pulse low time. Can you please help me how can I do that ?
Attached is the example file which measure high time. | Code: |
#include <18F452.h>
long rise,fall,pulse_width;
#int_ccp2
void isr()
rise = CCP_1;
fall = CCP_2;
pulse_width = fall - rise; // CCP_1 is the time the pulse went high
} // CCP_2 is the time the pulse went low
// pulse_width/(clock/4) is the time
// In order for this to work the ISR
// overhead must be less than the
// low time. For this program the
// overhead is 45 instructions. The
// low time must then be at least
// 9 us.
printf("\n\rHigh time (sampled every second):\n\r");
setup_ccp1(CCP_CAPTURE_RE); // Configure CCP1 to capture rise
setup_ccp2(CCP_CAPTURE_FE); // Configure CCP2 to capture fall
setup_timer_1(T1_INTERNAL); // Start timer 1
enable_interrupts(INT_CCP2); // Setup interrupt on falling edge
while(TRUE) {
printf("\r%lu us ", pulse_width/5 );
Posted: Sat Dec 03, 2011 5:56 am |
Just change these two lines:
To these:
setup_ccp1(CCP_CAPTURE_FE); // Configure CCP1 to capture rise
setup_ccp2(CCP_CAPTURE_RE); // Configure CCP2 to capture fall
These set which edges the code treats as the 'start', and 'stop' of the pulse. Swapping the edges as shown, means the 'rise' start point will now happen on the falling edge, and the 'stop' point on the rising edge.
Now if you wanted to be really 'elegant', and document this, then change all the mentions of 'rise' to 'start', and all mentions of 'fall' to 'stop', and change the comments on the lines to:
//Configure CCP1(start) to falling edge
//Configure CCP2(stop) to rising edge
waqas_shafique
Posted: Sat Dec 03, 2011 6:09 am |
| Thanks a lot for your help , I already come to this point few mins ago and problem solved. |
