can i receive character from RS232 while Timer0 is working?
anulikwutsayll
PostPosted: Thu Dec 01, 2011 10:12 am     Reply with quote
hi, everyone
this is my code
#include <16F688.h>
#fuses HS ,NOWDT,NOPROTECT
#use rs232(baud=9600, xmit=PIN_C3, rcv=PIN_C2 ,stream=PC)
char A;
int int_count = 0;
void main ()                                               //main function
   set_tris_a(0xFC);                                        //Set PortA
   enable_interrupts(GLOBAL);                         //All Interrupts on
   enable_interrupts(INT_TIMER0);                //Turn on Interrupt TIMER0
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);      //setup timer
   set_timer0(0);
       A = fgetc (PC);
       if A == 'e'
         == do something ==
#INT_TIMER0                                          //Function Interrupt TIMER0
void Timer0_ISR()
   if(int_count++>19)
      ++i;
      int_count =0;
   if(i>5000)
      == do something ==
thanks for help in advance
PostPosted: Thu Dec 01, 2011 10:19 am     Reply with quote
hmm..
Try it and find out ! Simple enough.
You will need to add 'errors' to the use RS232(....) options though...
asmboy
PostPosted: Thu Dec 01, 2011 11:08 am     Reply with quote
i can answer this very simply:
even if you tried to add an interrupt driven RS-232 receive routine-
sooner or later ( but probably sooner) because this is software RS-232- THIS WILL DISTORT reception and your RX ( && ||) TX data will be corrupt too.
this is especially acute since your fast timer rollover will darned near SATURATE the pic capability.
LOL do the math !!
you are generating almost 20,000 INTS / second !!!!
take it to the $$ bank - you MUST be VERY VERY new to pic programming is all i can guess Exclamation
PostPosted: Thu Dec 01, 2011 3:36 pm     Reply with quote
int int_count = 0;
if(i>5000)
== do something ==
The datatype is wrong. It should be int16.
It's a very common problem for new CCS users:
http://www.ccsinfo.com/forum/viewtopic.php?t=46501&start=3
http://www.ccsinfo.com/forum/viewtopic.php?t=46125&start=6
anulikwutsayll
PostPosted: Thu Dec 01, 2011 10:10 pm     Reply with quote
Thanks for suggestion.
And sorry about my simple question, I don't know that it's simple.
I have miss out this line when I typing.
int int_count = 0;
int16 i = 0;
Thanks for all advice Smile
