The Pre-Processor directive #ID CHECKSUM doesn`t stack with 18F66J60.
What can I do to solve this problem???
Posted: Fri Nov 25, 2011 2:43 pm
Post a short compilable test program. Post your compiler version.
Explain how you test it, and show how it doesn't work.
stoyanoff
Posted: Sat Nov 26, 2011 10:10 am
My CCS version is 4.78.
I`ve tried with something simple
#include <18F66J60.h>
#ID CHECKSUM
void main(){
and the compiler returns:
Invalid Pre-Processor directive No ID memory
When I'm trying with another controller everything is OK.
Could the problem be in the header file??
I'm using the heather from devices folder of the complier.
Is it possible the 18F66J60 to have not ID memory???
