CAN problem with dspic30f6010A
mitice
PostPosted: Thu Nov 24, 2011 5:09 am     Reply with quote
Hi everyone. I'm using dspic30f6010a with 10Mhz, and I set the Bit rate 500K. Now I encounter some problem that I can transmit data but not receive data. The following is my code. Could someone tell me how to modify.Thanks a lot. It never entered into can_kbhit().
   #include <30F6010A.h>
#fuses EC
#device *=16 ADC=12
#use delay(clock=10Mhz)
  can_init();
  can_set_mode(CAN_OP_CONFIG);   //must be in config mode before params can be set
//設定can baud rate 500k
   C1CFG1.brp=CAN_BRG_PRESCALAR;
   C1CFG1.sjw=CAN_BRG_SYNCH_JUMP_WIDTH;
   C1CFG2.prseg=CAN_BRG_PROPAGATION_TIME;
   C1CFG2.seg1ph=CAN_BRG_PHASE_SEGMENT_1;
   C1CFG2.sam=CAN_BRG_SAM;
   C1CFG2.seg2phts=CAN_BRG_SEG_2_PHASE_TS;
   C1CFG2.seg2ph=CAN_BRG_PHASE_SEGMENT_2;
   C1CFG2.wakfil=CAN_BRG_WAKE_FILTER;
//設定can 中斷
   enable_interrupts(INT_CAN1);
   can_enable_interrupts(RX0 | RX1 );
   can_set_mode(CAN_OP_NORMAL);
   can_putd(0x280,CAN_data,8,3,FALSE,FALSE);
   printf("Running...........\n");
     if ( can_kbhit() )   //if data is waiting in buffer...
          if(can_getd(rx_id, &buffer[0], rx_len, rxstat)) { //...then get data from buffer
         printf("\r\nGOT: BUFF=%U ID=%LU LEN=%U OVF=%U ", rxstat.buffer, rx_id, rx_len, rxstat.err_ovfl);
            printf("FILT=%U RTR=%U EXT=%U INV=%U", rxstat.filthit, rxstat.rtr, rxstat.ext, rxstat.inv);
            printf("\r\n    DATA = ");
            for (i=0;i<rx_len;i++) {
               printf("%X ",buffer[i]);
            printf("\r\n");
            if (rx_id == 300) {
               printf("GET DATA\r\n\r\n");
mitice
PostPosted: Wed Nov 30, 2011 12:11 am     Reply with quote
I try to operate in loop-back mode. It still didn't get the can message.
