I2C slave is not working with 16f1938
kongfu1
PostPosted: Tue Nov 22, 2011 12:45 am     Reply with quote
I2C slave is working when master requests one byte to read only. Every time when I2C master reads more than one byte, 16F1938 will hold clock line to be low until reset the chip.
Please help.
Howard
Here is slave interrupt:
#INT_SSP
void ssp_interupt ()
   BYTE incoming, state;
   state = i2c_isr_state();
   if(state <= 0x80)                     //Master is sending data
      incoming = i2c_read();
      if(state == 1)                     //First received byte is address
         address = incoming;
      if(state == 2)                     //Second received byte is data
         buffer[address] = incoming;
   if(state == 0x80)                     //Master is requesting data
      i2c_write(buffer[address]);
PostPosted: Tue Nov 22, 2011 9:48 am     Reply with quote
Of course it will......
You are not loading any data for the master to read, if it asks for more than one byte. I2C_ISR_STATE, will return 0x81, then 0x82 etc.. For these values the code does nothing, so the clock will be held low, waiting for the buffer to be loaded....
kongfu1
PostPosted: Tue Nov 22, 2011 12:26 pm     Reply with quote
Thanks for your quick reply. That was my mistake.
Another word is that, is there any hw timeout of PIC to release I2C clock line if the buffer was never loaded? In my case, reset PIC is only way to release I2C clock line.
Thanks,
Howard
PostPosted: Tue Nov 22, 2011 3:30 pm     Reply with quote
At the end of these threads, Ttelmah discusses how to implement
timeouts in i2c routines:
http://www.ccsinfo.com/forum/viewtopic.php?t=34634
http://www.ccsinfo.com/forum/viewtopic.php?t=43052
