Need support for Closed loop motor speed controller
tomal
PostPosted: Sun Nov 20, 2011 1:26 am     Reply with quote
At first I express my apology to post it here. But I'm learning CCS C and going to buy it due to its easiness so I thought I would post it here.
Anyway, my interest is actually to build a closed loop (AC/Universal) motor speed controller. Since I'm new to PIC, I need help from the PIC/CCS expert.
I'm ready to pay for your help and support. Please PM me if you can help.
PostPosted: Sun Nov 20, 2011 8:01 pm     Reply with quote
Look at the Microchip website. They have large numbers of motor
control PDF tutorials. Check out their motor design center page:
http://www.microchip.com/en_us/technology/motorcontrol/
PostPosted: Mon Nov 21, 2011 5:25 pm     Reply with quote
110v ??
how much current at 110v - unrestricted I input?
re servo -
attempting to go sensor less ?
or do you have hall/opto interrupters?
tomal
PostPosted: Mon Nov 21, 2011 11:12 pm     Reply with quote
It is not a servo but a single phase brushed AC (110/220V) motor and some people calls it universal AC motor.
I have drawn a basic schematic of the speed controller. Pls take a look.
Few words about the schematic:
1. I plan to use (28 pin) PIC18F2420 or 2520 and the circuit will be opto isolated from AC mains.
2. PS2505 multi-photocoupler will be used for zero cross detection. I might be used a selector for 50Hz/60Hz selection.
3. Output will be driven by the MOC3021/23, which will then trigger the triac.
4. The motor usually rotates at 25K RPM with full power. A pot will be used to control the speed between 5k to 25K. Reference voltage (for speed pot) will be 0v - 5v.
5. A reflective sensor (HOA1397) will be used in the motor for rotation count and RPM will be displayed. The same sensor will be used as feedback loop to maintain a constant speed. May be some PID algorithm need to be used. 2-5% speed variation is ok for the application.
Just an illustration:
The (220v/5A) motor is referenced for 5k RPM so it is rotating in the same speed at without load. But the speed will reduce as soon as I put some load on it. MCU will recalculate the revolution at this point and provide more power to maintain the referenced speed.
Hope above explanation will help.
tomal
Tachometer
PostPosted: Fri Dec 09, 2011 2:21 am     Reply with quote
Here is the tacho part.
Would you pls check if the calculations are right...do you think I'll get right RPM?
// Compiler: CCS PCWHD 4.120
#include <16F886.H>
#fuses HS               //High speed Osc (> 4mhz for PCM/PCH)
#fuses NOBROWNOUT       //No brownout reset
#fuses NOPROTECT        //Code not protected from reading
#fuses NOLVP            //No low voltage programing, B3(PIC16)
#fuses NOWDT            //No Watch Dog Timer
#FUSES NOPUT            //No Power Up Timer
//#FUSES PUT              //Power Up Timer
#use delay(clock=20M)    //20Mhz crystal
#define LCD_DB4   PIN_B1
#define LCD_DB5   PIN_B2
#define LCD_DB6   PIN_B3
#define LCD_DB7   PIN_B4
#define LCD_E     PIN_C5
#define LCD_RS    PIN_C4
#define LCD_RW    PIN_C6
// Tacho_PORT = PIN_C2
#include <flex_LCD.c>
#define START_TACH  0
#define RUN_TACH    1
#define DONE_TACH   2
// Global variables
static char cState;
static long iCount;
// Tach reading
#int_ccp1
void ccp1_isr(void)
    if ( cState == RUN_TACH ) // second edge
        iCount = CCP_1;       // get capture value
        cState = DONE_TACH;   // prevent further processing during this interrupt
    if ( cState == START_TACH )   // first edge
        set_timer1 (0);     // restart timer on this edge
        cState = RUN_TACH;
// MAIN FUNCTION
void main (void)
    int cCnt;
    float fRpm;
    int32 int32Count;
    // INITIAL MESSAGE
    lcd_init(); //LCD start
    lcd_putc("\f");  // Clear the LCD
    lcd_putc("TACHOMETER\n");
    // SETUP TIMER 1
    setup_timer_1(T1_INTERNAL);
    // SETUP CCP1
    setup_ccp1(CCP_CAPTURE_RE);          // capture every rising edge
    // ENABLE INTERRUPTS
    clear_interrupt(INT_CCP1);
    enable_interrupts(INT_CCP1);     // CCP1 interrupt
    enable_interrupts(GLOBAL);       // enable all interrupts
    cState = DONE_TACH;
    while (1)
        int32Count = 0;
        for ( cCnt = 0; cCnt < 20; cCnt++ )    // accumulate 20 readings
            cState = START_TACH;                // allow interrupt to start
            while ( cState != DONE_TACH )       // wait for timing to complete
                if ( get_timer1() > 60000 )  // timeout counter
                    iCount = 0;              // zero everything out
                    int32Count = 0;
                    break;                   // don't wait any longer
            int32Count += iCount;        // otherwise accumulate
        int32Count /= 20;                // get average of those 20 readings
        fRpm = 1 / ((float)int32Count);  // period in uS
        fRpm *= 1000000;                 // period in seconds
        fRpm *= 60;                      // period in minutes
        //DISPLAY RPM
        lcd_gotoxy(1,2);    //Goto second line
        printf(lcd_putc, "%0.0f RPM      ", fRpm);  //Show RPM
