Code for hire ( Graphic LCD code "ST7565R ")
kbruin79
PostPosted: Tue Jan 25, 2011 5:11 pm     Reply with quote
I am planning to use a graphic LCD by newhaven that uses the ST7565R controller. The code library for ST7565R is written in C for AVR so I need help to convert it to CCS and possibly add a big font feature to the code.
Please let me know if you're able to help and how much will you charge?
Here is the open source code: https://github.com/adafruit/ST7565-LCD
Here is the LCD that I am planning to use: http://www.mouser.com/Search/ProductDetail.aspx?qs=jAHslVI6snuT2SwKL81Irw%3D%3D
I am using Pic16F727.
picprogrammer
PostPosted: Fri Nov 18, 2011 3:19 am     Reply with quote
Did you made any progress? Can you share code with us?
Mark
msakms
ST7565R DRIVER
PostPosted: Sun Nov 20, 2011 8:14 am     Reply with quote
Here you are bro, feel free to inform me about any doubts you have and maybe we can all discuss any tweaks & optimization changes that might come in handy.Very Happy
//  ST7565R-FUNCTION PROTOTYPES:        //
//  void CMD_MODE()----->Instructions Command Mode                                         //
//  void DRAM_MODE()------->Display-RAM Mode                                               //
//  void CLK_IN()--------> Enable pin clocking-in                                          //
//  void INIT_LCD()------>GLCD initialization                                              //
//  void PRINT(char letter)--------->Character or string print function between quotes.    //
//  void CLEAR_LCD()------>Clear the GLCD                                                  //
//  void GOTO_PAGE()------>Goto p=PAGE ADDRESS and c=COLUMN ADDRESS                        //
//  msakms-ST7565R V1.0        //
#Define RD PIN_C3
#Define A0 PIN_C4
#Define WR PIN_C5
#Define CS1 PIN_C6
#Define LCD_RESET PIN_C7
unsigned int init[]={0x40,0xA0,0xC8,0xA6,0xA3,0x2F,0xAD,0x00,0xAF,0xA4};
unsigned int d, c, x, i2, ln, un, i;
static unsigned int p;
unsigned int const ps = 0xB0;
char letter;
const byte TEXT[39][6]= {
                         0x7E, 0x09, 0x09, 0x09, 0x7E, 0x00,  //A
                         0x7F, 0x49, 0x49, 0x36, 0x00, 0x00,  //B
                         0x3E, 0x41, 0x41, 0x41, 0x00, 0x00,  //C
                         0x7F, 0x41, 0x41, 0x41, 0x3E, 0x00,  //D
                         0x7F, 0x49, 0x49, 0x49, 0x00, 0x00,  //E
                         0x7F, 0x09, 0x09, 0x09, 0x00, 0x00,  //F
                         0x3F, 0x41, 0x49, 0x79, 0x00, 0x00,  //G
                         0x7F, 0x08, 0x08, 0x08, 0x7F, 0x00,  //H
                         0x00, 0x41, 0x7F, 0x41, 0x00, 0x00,  //I
                         0x60, 0x41, 0x7F, 0x01, 0x00, 0x00,  //J
                         0x7F, 0x08, 0x04, 0x0A, 0x71, 0x00,  //K
                         0x7F, 0x40, 0x40, 0x40, 0x00, 0x00,  //L
                         0x7F, 0x02, 0x04, 0x02, 0x7F, 0x00,  //M
                         0x7F, 0x02, 0x04, 0x08, 0x7F, 0x00,  //N
                         0x3E, 0x41, 0x41, 0x41, 0x3E, 0x00,  //O
                         0x7F, 0x09, 0x09, 0x09, 0x06, 0x00,  //P
                         0x3E, 0x41, 0x61, 0x7E, 0x80, 0x00,  //Q
                         0x7F, 0x09, 0x19, 0x29, 0x46, 0x00,  //R
                         0x46, 0x49, 0x49, 0x49, 0x31, 0x00,  //S
                         0x01, 0x01, 0x7F, 0x01, 0x01, 0x00,  //T
                         0x3F, 0x40, 0x40, 0x3F, 0x00, 0x00,  //U
                         0x07, 0x18, 0x60, 0x18, 0x07, 0x00,  //V
                         0x7F, 0x80, 0x70, 0x80, 0x7F, 0x00,  //W
                         0x63, 0x14, 0x08, 0x14, 0x63, 0x00,  //X
                         0x03, 0x04, 0x78, 0x04, 0x03, 0x00,  //Y
                         0x31, 0x29, 0x25, 0x23, 0x21, 0x00,  //Z
                         0x00, 0x00, 0x00, 0x00, 0x00, 0x00,  //SPACE
                         0x42, 0x7F, 0x40, 0x00, 0x00,0x00,  //1
                         0x62, 0x51, 0x4D, 0x46, 0x00,0x00,  //2
                         0x41, 0x45, 0x4B, 0x31, 0x00,0x00,  //3
                         0x3C, 0x22, 0x7F, 0x20, 0x00,0x00,  //4
                         0x47, 0x45, 0x45, 0x39, 0x00,0x00,  //5
                         0x7E, 0x49, 0x49, 0x31, 0x00,0x00,  //6
                         0x01, 0x79, 0x05, 0x03, 0x00,0x00,  //7
                         0x3E, 0x49, 0x49, 0x3E, 0x00,0x00,  //8
                         0x06, 0x09, 0x09, 0x7F, 0x00,0x00,  //9
                         0x7F, 0x41, 0x41, 0x7F, 0x00,0x00,  //0
                         0x00, 0x00, 0x40, 0x00, 0x00, 0x00, //.
                         0x07, 0x05, 0x07, 0x00, 0x00, 0x00};//Celcius
void CMD_MODE() {
     output_low(A0);
     output_high(RD);
     output_low(WR);
void DRAM_MODE() {
    output_high(A0);
    output_high(RD);
    output_low(WR);
void CLK_IN() {
     output_low(CS1);
     output_high(CS1);
void INIT_LCD() {
   //INITIALIZATION ROUTINE//
    output_low(LCD_RESET);
    output_high(LCD_RESET);
    CMD_MODE();
    for(i=0;i<10;i++)
        output_d(init[i]);
        CLK_IN();
//END OF INITIALIZATION ROUTINE//
void GOTO_PAGE(p,c) {
    CMD_MODE();
    d = ps + p;
    output_d(d);
    CLK_IN();
    ln = c & 0b00001111;
    un = c & 0b11110000;
    un = un >> 4;
    un = un | 0b00010000;
    output_d(un);
    CLK_IN();
    output_d(ln);
    CLK_IN();
void PRINT(char letter) {
    switch(letter){
      case 'A':
       x = 0;
      case 'B':
       x = 1;
      case 'C':
       x = 2;
      case 'D':
       x = 3;
      case 'E':
       x = 4;
       case 'F':
       x = 5;
       case 'G':
       x = 6;
       case 'H':
       x = 7;
       case 'I':
       x = 8;
       case 'J':
       x = 9;
       case 'K':
       x = 10;
       case 'L':
       x = 11;
       case 'M':
       x = 12;
       case 'N':
       x = 13;
       case 'O':
       x = 14;
       case 'P':
       x = 15;
       case 'Q':
       x = 16;
       case 'R':
       x = 17;
       case 'S':
       x = 18;
       case 'T':
       x = 19;
       case 'U':
       x = 20;
       case 'V':
       x = 21;
       case 'W':
       x = 22;
       case 'X':
       x = 23;
       case 'Y':
       x = 24;
       case 'Z':
       x = 25;
       case ' ':
       x = 26;
      case '1':
       x = 27;
      case '2':
       x = 28;
      case '3':
       x = 29;
      case '4':
       x = 30;
       case '5':
       x = 31;
       case '6':
       x = 32;
       case '7':
       x = 33;
       case '8':
       x = 34;
       case '9':
       x = 35;
       case '0':
       x = 36;
       case '.':
       x = 37;
       case '°':
       x = 38;
    DRAM_MODE();
    for(i=0;i<6;i++)
        output_d(TEXT[x][i]);
        CLK_IN();
void CLEAR_LCD() {
      for(i2=0;i2<4;i2++) {
        GOTO_PAGE(i2,0);
        for(i=0x00;i!=0x83;i++)
        DRAM_MODE();
        output_d(0x00);
        CLK_IN();
I'm using a PIC16F877-A @ 4MHz "So no need to check the busy flag because the timing is just perfect at such frequency" and the TOPWAY LM13232AFW 132x32 GLCD module. Make sure you check your product datasheet for any changes that you might need.
picprogrammer
PostPosted: Mon Nov 21, 2011 4:29 am     Reply with quote
I'm still at the lcd selection process. We need a 3V3 text or graphic display.
kbruin79
Re: ST7565R DRIVER
PostPosted: Tue Feb 21, 2012 5:20 pm     Reply with quote
Thank you for the code ! I will test it out and let you how it works.
