ünloco
weird behaviour of "size of" |
Posted: Wed Nov 16, 2011 7:46 am |
hello
i have this array
int nums[10][6] = {
{0x38,0x44,0x44,0x44,0x38,0x0}, //0
{0x40,0x7C,0x0,0x0,0x0,0x0}, //1
{0x4C,0x54,0x54,0x54,0x34,0x0}, //2
{0x44,0x54,0x54,0x54,0x28,0x0}, //3
{0x70,0x10,0x10,0x10,0x7C,0x0}, //4
{0x74,0x54,0x54,0x54,0x48,0x0}, //5
{0x38,0x54,0x54,0x54,0x8,0x0}, //6
{0x40,0x40,0x4C,0x70,0x0,0x0}, //7
{0x28,0x54,0x54,0x54,0x28,0x0}, //8
{0x20,0x54,0x54,0x54,0x38,0x0} //9
when i use a variable that contains the index (n1) then "size of" gives me bad values !!
Code: | n1 = 2;
width = sizeof nums[2]; //gives width = 6 and that's ok
width = sizeof nums[n1]; //gives width = 2 !!! |
what's wrong ?? _________________ for(;;); |
RF_Developer
Posted: Wed Nov 16, 2011 8:37 am |
Hmm... in C nums[0] is a pointer. Normally sizeof(a pointer) returns the size of the pointer, i.e. 2 in CCS generally. Using sizeof() with an array is a special case, and should the size of the array, not the the size of the pointer. C implements arrays with pointers remember and C arrays can be indexed or accessed through pointers interchangably. Note, if you had:
n1 = 2;
int *P = nums[2]; // P is now interchangable with nums[2].
then the following should happen:
width = sizeof(P); // should be 2, i.e. sizeof(int *)
So, for some reason, CCS is interpreting sizeof(nums[2]) as the special case - tick VG - but sizeof(nums[n2]) as the normal, i.e. pointer case - not so good, must do better. The use of the variable is breaking the special case of sizeof for arrays... However the two are evaluated at very different times. sizeof(nums[2]) is in this case known at compile time, whereas sizeof(nums[n1]) has to be evaluated at run time. If nums[] was a ragged array, i.e. its elements not defined at compile time then sizeof(nums[2]) would also not be known at compile time. This makes sizeof() more tricky for compiler writers than we might at first expect.
RF Developer |
Posted: Wed Nov 16, 2011 8:41 am |
Sizeof, is computed at compile time, so trying to access an element indexed by a variable simply won't work. You get '2', because the compiler decides you want the storage size of the pointer to the row represented, and this (of course) is 2.
I see RF_Developer has pointed this out as well, while I'm typing.
ünloco
Posted: Wed Nov 16, 2011 1:59 pm |
thank you guys !
now it's clearer as to why
i'll avoid such use
greetz _________________ for(;;); |
