Help_INTERRUPT
malu79
Help_INTERRUPT
PostPosted: Wed Nov 16, 2011 2:28 am     Reply with quote
Hi, I write because I need clarification on the use of the interrupt. I wrote some time ago and in this regard I refer to the example provided by the CCS that the file EX_PATG. Some might explain this example? I need to flash 4 LED with frequency from 1 Hz to 60 Hz in 1 Hz steps going but I can not set the interrupt value; use a clock = 20000000 and a baud rate of 115200.
Thanks and sorry for not perfect English.
PostPosted: Wed Nov 16, 2011 8:53 am     Reply with quote
You could look at the example that CCS provides in the 'examples' folder.
Named 'EX_STWT.C", it should help you
also in the 'code library' here ont he forumn, there's a SW RTC program, that works very well and easy to 'trim' down to just sending 'main' a 'flag' every second instead of the full function RTC that is coded.
PostPosted: Wed Nov 16, 2011 3:14 pm     Reply with quote
Please don't start a new thread for each question about Ex_Patg.c,
because you already have a thread on it here:
http://www.ccsinfo.com/forum/viewtopic.php?t=45727
This thread has an explanation of Ex_patg.c by ckielstra:
http://www.ccsinfo.com/forum/viewtopic.php?t=33907
