georpo
Joined: 18 Nov 2008 Posts: 281 Location: Athens, Greece.
fastest PIC |
Posted: Sun Nov 06, 2011 8:41 am |
I am currently using a PIC24HJ256GP206 overclocked at 100MHz giving 50MIPS
but I need something much faster in order to display video on a TFT display.
So, which is the fastest PIC supported by CCS?
Thanks! _________________ George. |
bkamen
Re: fastest PIC |
Posted: Sun Nov 06, 2011 9:22 am |
georpo wrote: | Hello,
Use the PIC24FJ256DA210
Has a built in hardware video controller that does the work for you in hardware...
georpo
Posted: Fri Nov 11, 2011 10:34 am |
The PIC24FJ256DA210 is much slower than the one I use.
It is not a matter of graphics etc. The video is stored as bitmaps in a SD card. I just need faster data transfer when writing on the 16bit bus.
Right now my TCY is 50MHz giving 20nS instruction cycle.
I need something 5 times faster than this.
So, again to the starting question.
Which is the fastest PIC supported by CCS?
Thanks. _________________ George. |
bkamen
Posted: Fri Nov 11, 2011 12:19 pm |
georpo wrote: | The PIC24FJ256DA210 is much slower than the one I use.
let's review.
In your previous post, you said you're transfering graphics to a TFT display over the 16bit bus of a PIC. And you need speed.
I'm guessing (not assuming) you're driving the TFT display directly without a controller...
In which case, I suggest a PIC with a built in LCD display controller.
Then you tell me, "It's not a matter of graphics."
Um. Ok.
Well, unless you're using 4bit SDcard transfers, you're going to be spending your largest bottleneck there.
After that, if you are really driving the display directly, you're wasting a lot of CPU power on driving the LCD.
I'm guessing you've actually picked the wrong microcontroller for the job.
Good luck,
Posted: Fri Nov 11, 2011 12:30 pm |
You can use this Microchip tool to find fast PICs:
http://www.microchip.com/maps/microcontroller.aspx
Choose the basic type of PIC in the box on the upper left. Also, click on
the little + in the corner, so you can see tickboxes for "Current, Future, etc.
Then go down to the row for "Max CPU Speed", and select the MIPS that
you want. For example, to get a mininum of 60 MIPS select that for the
first column but leave the 2nd column as -All-.
The page will automatically update in a couple seconds, after you make
any change. The list of suitable PICs will appear in the Search Results box. |
georpo
Posted: Fri Nov 11, 2011 1:59 pm |
The TFT panel has built in SSD1963 controller.
It is not driven directly from the PIC.
Imagine that I had a really fast card that can give me the desired speed
or that I had all the bitmaps in RAM. Not possible. I know. Just imagine.
So, what I would need is to feed the 16bit bus so fast:
480x272 pixels = 13560 pixels x 3 bytes/pixel (for 24 bit color)
=391680 bytes per frame.
391680 bytes /2 (because it is a 16bit bus) = 195840 words x 25 frames/sec
=4896000 words/second.
This is not so fast but think that before each word write, the PIC
has to calculate and shift the RGB bytes in the word to be written.
With the current PIC running at 50MHz, this is what I get:
ftp://user:12131547@georpo.dyndns.org/2GBSD/graph.jpg
This is taken from the /WR pin. It takes 664nS for 3 words transfer.
I am thinking of going NXP ARM. _________________ George. |
n-squared
Posted: Sat Nov 12, 2011 3:24 pm |
Hi
Microchip has released a new family of PI24 chips that run at 60MIPS.
The PIC24EP256GU810-I/PF is a 100TQFP device with 24K bytes of RAM.
BR
NN _________________ Every solution has a problem. |
drolleman
Posted: Sun Nov 13, 2011 12:53 pm |
Looking at the scope output there appears to be a lot of load / capacitance that is causing the signal to look like it does. You need to make the traces as short as possible, but thick enough to carry the current.
The other thing to do is pre-create your image in ram. Also this may look good in code 'Write_Data((color)>>16)' but expensive in clock cycles at runtime. Have this broken up before you write to the screen.
char colorR[20] = {20,5,2...
char colorG[20] = {24,56,12...
char colorB[20] = {20,51,27...
output_low(CS);//CS = 0;
output_d(colorR[clr]P1 = command;
output_high(CS);//CS = 1;
delay_cycles(2);
output_d(colorG[clr]P1 = command;
delay_cycles(2)
output_d(colorB[clr]P1 = command;
This writes to the controller as fast as it can and a 24FJ can write where you see no flickering on the screen even 640x480.
Creating a loop so that the code looks cleaner will also slow it down. So if the purpose is to speed it up, then think of what the controller has to do to run this. Look at the .lst file as to what the controller has to do. |
georpo
Posted: Mon Nov 14, 2011 12:24 pm |
This is what I use to fill all 480*272 pixels with a color.
Color is a 32 bit value, I use the 24 lower bits to represent 8 bits for RED, 8 bits for GREEN and 8 bits for BLUE.
Data is packed in 16 bit format and requires 3 writes in order to fill 2 pixels:
RG 1st word contains RED and GREEN of 1st pixel
BR 2nd word contains BLUE of 1st pixel and RED of 2nd pixel
GB 3rd word contains GREEN and BLUE of 2nd pixel
void fill_screen(int32 color){
WindowSet(0,479,0,271); // tell the controller the area we are going to write to.
WriteCommand(0x2c); //command to start receiving data
RS=1; //select DATA register
for(x=0;x<65280;x++){ //480*272=130560 / 2 =65280
BUS=COLOR>>8;
WR=0;
WR=1;
BUS=COLOR<<8 |( COLOR>>16 & 0xFF);
WR=0;
WR=1;
BUS=COLOR& 0xFFFF;
WR=0;
WR=1;
If I just toggle the /WR pin like this:
While(1){
output_high(WR);
output_low(WR);
Then I have 25MHz at the oscilloscope. More than enough!
But as you see above, all this calculation before the actual write,
give me a very slow transfer rate.
As about the pre-create image in RAM isue, it is a good idea
but as you can see a full image is 391680 BYTES= 195840 WORDS. No ram can hold this!
Am I missing something??
drolleman
Posted: Mon Nov 14, 2011 3:05 pm |
When i indicated in ram, you use intelligent writing, where writing is required only. If a object needs updating then update that object. You don't create a raw image in ram but its color / format / location / what it is. This uses very little ram. For fill areas use the fast fill method.
eg. button
put outline of button
fill inside
write char's
It's the fill that usually takes the most time to write, since cpu cycles / pixel comes into play. The more complex, the more cpu cycles required to get the job done. I like to use a scope to tell me how long it takes to do something. or use the stopwatch in the realice to help trim how long it takes to do something.
If I'm writing a 7 seg item than I pre-format in ram. Usually it is fgcolor / bkcolor this only uses 1 bit per pixel even if you use 64k color! very little ram used. So when sending it to the controller it's very fast.
This method doesn't work on images, then you would need enough ram to support full image in ram. Or the video controller would need paging capabilities. |
