#bit testing
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
#bit testing
PostPosted: Fri Nov 11, 2011 11:17 am     Reply with quote
Wondering why I can't do this:
#byte CCP6CON = 0xF71
#bit CCP6IF = PIR4.1
#bit CCP6M0 = CCP6CON.0
and in my code:
   if (CCP6MO++) {
      rise3 = CCP_6;
   } else {
      fall3 = CCP_6;
I have to do this instead, using an int1 iRise3: I thought by using #bit I would save a few instructions. I thought #bit variables worked like an int1?
   if (iRise3++) {
      rise3 = CCP_6;
      CCP6M0 = 0; // Set for capture on falling edge
   } else {
      fall3 = CCP_6;
      CCP6M0 = 1; // Set for capture on risiing edge
PostPosted: Fri Nov 11, 2011 1:50 pm     Reply with quote
Change the font for your text editor so it has a slashed zero.
Then you will more easily be able to see if you typed a zero or a capital O.
The FixedSys font has a slashed zero.
PostPosted: Fri Nov 11, 2011 4:31 pm     Reply with quote
The suggestion was a bit too cryptic for me to pick up at first time, but yes, on my old v4.077 the first code compiles when I fixed the typo in the variable name. Smile
PostPosted: Fri Nov 11, 2011 4:42 pm     Reply with quote
I know. I answered that way because I mischievously wanted the O.P.
to look closely at his variable names. Cool
PostPosted: Fri Nov 11, 2011 5:56 pm     Reply with quote
You are terrible. Cool
