Function Delay_sec for 1 sec
void Delay_sec(void)
hear OK ?
NOW I CAN USE LIKE ? ...
if (Delay_sec>260)
BlinkLED3();
_________________ sahu
vortexe9000
Joined: 07 Jun 2010 Posts: 50 Location: Banned - spammer
hi...
Posted: Mon Nov 07, 2011 1:57 pm
sqsdf532 _________________ Banned for spamming his own posts
SherpaDoug
Posted: Mon Nov 07, 2011 2:17 pm
Delay_sec is a function that returns void. So your IF statement waits one second and then compares void to 260. I would expect the compiler to gag. _________________ The search for better is endless. Instead simply find very good and get the job done.
sahu77
Posted: Tue Nov 08, 2011 2:38 am
can you give 1 example ? _________________ sahu
Posted: Tue Nov 08, 2011 5:36 am
Sorry, we can not help you because we do not understand what you want to do. Please explain more.
Gabriel
Posted: Fri Nov 11, 2011 12:20 pm
Quick answer: Wrong.
Declare a global
int Seconds;
Change your function declaration to
Int Delay_sec()
Int Delay_sec()
Seconds++;
Return(Seconds)
if (Delay_sec>255)
BlinkLED3();
.... as above should do what you want... but only upto 255 seconds.
.... you have to place your Delay_Sec function inside a loop though..or somthing... that calls it the amount of time you want ... you can use the Seconds variable you declared as the counter for the loop...
.... you can figure it out from here...
but the above makes your code stay in the loop for upto 255 seconds... which makes your code HORRIBLE... and renders your PIC useless for a hell of a long power wasting time...which is what everybody else here has been telling you...
for such long delays... its probably better to have an external RTC with alarm... or 1hz signal and have it interrupt... and count that...
or a zillion smaller interrupts using the timers... somthing else other than calling a delay function until you get the desired delay...
its possible but bad idea.
