Cmed
74164 for 8X8 Matrix LED -Help |
Posted: Tue Nov 01, 2011 6:31 pm |
Hi everyone,
I tried to write a letter on 8X8 LED MATRIX but the display isn't stable,
when I run it under STEP BY STEP, it works but when I run it normally it doesn't!!!!!
Please i need your help on that problem:
//C Med Matrix LED-----------------------------------------------------
#include <16F876A.h>
#device adc=8
#FUSES XT //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#define DATA pin_a3
#define CLOK pin_a2
int i;
int Shdata[8]={0xFF,0xFF,0x70,0x38,0x70,0xFF,0xFF,0x00}; // M Letter
void HCLK164(int a)
switch (a)
case 0: output_high(DATA);break;
case 1: output_low(DATA);break;
case 2: output_low(DATA);break;
case 3: output_low(DATA);break;
case 4: output_low(DATA);break;
case 5: output_low(DATA);break;
case 6: output_low(DATA);break;
case 7: output_low(DATA);break;
output_high(CLOK);
delay_us(10);
output_low(CLOK);
//Main Program------------------------------------------------------------------
for(i=0;i<8;i++)
HCLK164(i);
output_B(~Shdata[i]);
// HCLK164(i); when i put it here and i delete the above one it works half!!!
delay_ms(6);
I give you too the picture of simulation if you want to try it.
**THANK YOU SO MUCH** |
Cmed
No one find a solution!!!!! |
Posted: Wed Nov 02, 2011 6:44 am |
I need help in this as soon as possible please |
Mike Walne
Matrix Display |
Posted: Wed Nov 02, 2011 9:38 am |
You don't describe the nature of the instability.
I suspect you have fallen into an old trap.
Without input from you, I guess you are suffering from leakage.
The usual problem with multiplexed displays is data from one row (or column) leaking into the next. (Depends on which way round your matrix is connected)
What you are attempting to do is strobe each column in turn with the output from your 74164 as you sequence through the column data.
Unfortunately there is a brief period when LEDs in the wrong column are lit as you advance the strobe. The effect on the display is a faint glow from some LEDs which should not be lit at all.
What you need to do is:-
1 Turn all the LEDs off.
2 Advance the strobe.
3 Turn the LEDs on with the next set of data.
4 Wait, then repeat from 1.
Mike
PS. I would not use the software timer to multiplex the display. It's usually better to use one of the built in timers and interrupt control. That way your display takes care of itself as a background task with minimal flickering |
Cmed
Re: Matrix Display |
Posted: Wed Nov 02, 2011 12:50 pm |
Mike Walne wrote: |
Mike
Thank you MIKE,
It's kind from you but i think that i did these steps until you asked me to do so...
So please can you send me a small code just to write a letter on my MATRIX
I'm a beginner in CCS and the time is running out of me.
Thank you once more |
Mike Walne
Instability |
Posted: Thu Nov 03, 2011 5:13 pm |
What is the nature of the instability on your display?
In other words, describe what are you seeing.
At this stage you are leaving me to guess at the what your problem is.
You are trying to implement a multiplexed display.
The PIC you're using is more than capable of giving satisfactory results.
I see that you are strobing at ~6ms intervals. This means you are updating your display once every ~48ms (8*6ms). 48ms equates to 20Hz which is far too slow. At that kind of frequency you will be able to see a ripple effect through the matrix. As I said before use one of the built in timers and an interrupt.
I also don't see any current limiting resistors around your matrix. Are they built into the LED matrix? Or are you relying on the limited current capability of your silicon chips?
Like the other contributers to this forum I urge you write your own code. That way you'll learn a lot more. I'll give advice and hints but I don't have time to produce debugged code for you.
Mike |
