Ezequiel Guest
| Baudrate Selection Routine |
Posted: Fri Feb 07, 2003 5:57 pm |
I have a program where I need to establish a comm. with a ECU (Electronic Control Unit), this unit can operate at 9600bps or 10400bps. But to start the comm. I have to send a command at 5Bps. Fortunately I can do this using Output_low and Output_High and a Delay of 200mS. Then the ECU reply with 0x55 (a good Sync Byte, but I don't know how to use it) and two Data Bytes at 9600bps or 10400bps 8Bits No Parity Inverted. The problem is that I don't know at which baudrate the ECU is going to use. I try to modify the timed_getc() routine (which appears on a FAQ in the website) with no success. Another problem is that the rest of the program has to communicate also at this baudrate (to send and receive).
I tried to use the HUSART and Set_Usart_Speed (To change between 9600bps and 10400bps) but then I cannot send the command at 5Bps using Output_low and Output_High, at I cannot set the USART to 5Bps.
I find two possible solutions.
A) Send the command (Using any pin but not the USART) at 5Bps, and look in the SyncByte (0x55) to decide which baudrate to use.
B) Send the command (Using any pin but not the USART) at 5Bps, wait for 1.5Sec the SyncByte (0x55) at 9600bps, If it comes the rest of the program has to use this baudrate. If not, change to 10400bps, re send the command, and wait for 1.5Sec the Sync Byte at 10400bps. If it comes the rest of the program has to use this baudrate, if not there is no ECU to communicate with, and goto the beginning of the program.
I would like to know if it's possible to do this, which option is more easy to implement, and if somebody can help me with this little routine.
Here I send you the code (which is very short), it's unfinished but you can see which micro I'm using and so on.
Thank you very much,
Ezequiel
#include <16F76.h>
#device *=16
#fuses HS,NOWDT
#use RS232(baud=9600,xmit=PIN_C5,rcv=PIN_C4,Invert,Stream=ECU)
#include <LCD.C>
Unsigned Char SyncByte,KW1,KW2,ACKByte;
Unsigned Char BlkIndex,Line,Command; //Protocol Header
Unsigned Char ECUID[20];
#define TXPin PIN_C5 //Used to send Command at 5Bps
//Configuracion de perifecicos Integrados
setup_adc_ports(NO_ANALOGS);
setup_spi(FALSE);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
delay_ms(750);
//Inicia LCD
lcd_init();
//Start Up Screen
output_low(TXPin);
output_low(Driver);
delay_ms(750);
lcd_putc('\f');
lcd_putc("ECU Test");
lcd_putc('\n');
lcd_putc("E.L. Aceto");
delay_ms(2000);
//Here I send command (0x41) at 5Bps 7bits with Parity
output_low (TXPin);
output_high(Driver);
delay_ms(750);
//Este es el comando
output_high (TXPin);
delay_ms(200);
output_low (TXPin);
delay_ms(200);
output_low (TXPin);
delay_ms(400);
//Now I have to rcv 0x55 and two data bytes at 9600bps or 10400bps
//Here it goes the rutine that implement the baudrate detection
___________________________
Original Post ID: 11417 |
| Re: Baudrate Selection Rutine |
Posted: Fri Feb 07, 2003 6:45 pm |
:=Hello,
:= I have a program where I need to stablish a comm. with a ECU (Electronic Control Unit), this unit can operate at 9600bps or 10400bps. But to start the comm. I have to send a command at 5Bps. Fortunately I can do this using Output_low and Output_High and a Delay of 200mS. Then the ECU reply with 0x55 (a good Sync Byte, but I don't know how to use it) and two Data Bytes at 9600bps or 10400bps 8Bits No Parity Inverted. The problem is that I don't know at which baudrate the ECU is going to use.
The 16F76 has a hardware USART. For some reason you are not
using it. I guess the reason is because you need to send
the initial byte at 5 BPS. But if did use the USART, then
you can detect if you get a framing error. If you get one,
then switch to the other baud rate.
The following code shows the basic idea. I don't guarantee
this exact will work. For example, I don't know if the
set_uart_speed() function will actually set it for 10400 bps
because I never use that speed. Also, possibly you should
compare the received sync byte to 0x55. That may be a
sufficient test.
To use this method, you need to receive chars on PIN C7,
but transmit them on pin C5 (which is a non-USART pin).
You could set them up as different streams, perhaps.
These are just some ideas. There may be a way to do it
when using the software usart for receiving. I always
use the hardware usart, so that's why I'm giving you this
method. Other people on this forum may suggest a way to
do it with the software usart.
// Use the Hardware USART, and use the ERRORS directive.
<PRE>
main()
char c;
send_5BPS_byte();
c = getc(); // Wait for sync byte
if(bit_test(rs232_errors, FERR_BIT))
reset_uart(); // Reset port before changing baudrate
set_uart_speed(10400);
// etc.
// FUNCTIONS
void reset_uart(void)
bit_clear(RCSTA, SPEN_BIT); // Reset the serial port
delay_ms(1);
bit_set(RCSTA, SPEN_BIT);
delay_ms(1);
</PRE>
Original Post ID: 11418 |
