SPI2 read does not work on dsPIC30F6014A
YUM
PostPosted: Thu Oct 27, 2011 7:52 am     Reply with quote
I do a simple read on the SPI2 of a dsPIC30F6014A.
No way to get it run - the read value is always 0x00.
Here is the code snippet of some settings:
/* global header                                    */
/* YUM                                             */
/* global.h, 06/11                                    */
/* compile with CCS - 4.119, MPLAB 8.76                     */
#include   <30F6014A.h>
#device *=16 adc=12
// due to a silicon bug of the PIC processor, the fuses are set manually:
#FUSES 1=0x8705
#FUSES 2=0x003F
#FUSES 3=0x87A3
#FUSES 4=0x310F
#FUSES 5=0x330F
#FUSES 6=0x0007
#FUSES 7=0xC003
#ZERO_RAM
#define VERSION 0x0611
#define Fosc 40000000
#ID VERSION
#TYPE  SHORT=8, INT=16, LONG=32
#USE FIXED_IO(a_outputs=PIN_A6, PIN_A7, PIN_A9, PIN_A10, PIN_A13, PIN_A14, PIN_A15)
#USE FIXED_IO(b_outputs=PIN_B2, PIN_B3, PIN_B5, PIN_B6, PIN_B7, PIN_B8, PIN_B9, PIN_B10, PIN_B11, PIN_B14)
#USE FIXED_IO(c_outputs=PIN_C1, PIN_C2, PIN_C3, PIN_C4)
#USE FIXED_IO(d_outputs=)
#USE FIXED_IO(f_outputs=PIN_F6, PIN_F8)
#USE FIXED_IO(g_outputs=PIN_G6, PIN_G8, PIN_G9, PIN_G15)
#USE delay(clock = Fosc)
#use rs232(baud=9600, UART1, parity=N,bits=8)[b]
Here is the code snippet of the subroutine:
// read the keypad
char up_key_read_the_keypad(void)
 char read_value;
 setup_spi2(spi_master | SPI_MODE_0 |spi_clk_div_128 | SPI_MODE_8B);
 CS_KEY_OFF();
 CS_KEY_ON();
 delay_us(10);
 read_value = spi_read2(0xf3);
 delay_us(10);
 CS_KEY_OFF();
printf("  read value: %02X\r\n", read_value);
 return read_value;
Here is the screenshot of the signals and the serial test-output:
As you can see, all signals are present; the serial input (miso) is NOT static 0,
but most of the time 1
, so changing the spi modes will not help.
The spi is even running very slowly.
Any ideas?
PostPosted: Thu Oct 27, 2011 8:29 am     Reply with quote
I don't see SPI_MODE_0 defined in your code, thus I wonder what's missing else. But there's no obvious reason, why spi_read2 should read 0x00 with the shown waveforms, provided you connected the right SDI2 pin.
