very dumb question... Solved
Gabriel
PostPosted: Sat Oct 22, 2011 9:22 am     Reply with quote
hi,
I have a serial device that ouputs via RS232 numbers 0-9, *, #
(serial keypad).
IF(var=='#'){blah;}
# is a special character... how do I make the above comparison?
What is the special character I should place before # so that its take as a value and not as if were trying to do a #define....
IF(var=='\#'){blah;}
like above? I had a similar problem trying to print (") .... where I had to use \"
Sorry for the dumb question...
thanks.
CCS PCM 5.078 & CCS PCH 5.093
FvM
PostPosted: Sat Oct 22, 2011 9:52 am     Reply with quote
'#' doesn't need to be escaped, neither in printf format strings nor other character and string literals.
PostPosted: Sat Oct 22, 2011 10:09 am     Reply with quote
Nothing 'special' about the # key.
Since your device outputs the keypresses as serial, just use a 'terminal program'(I use Realterm) to show you what the serial keyboard is sending, vis RS232, for the keypresses.Be sure to get the baud,parity,stops bits correct !
If it's a straight ASCII lookup table then your device should send a decimal 35 ( hex 23) for the # key.
There are NO 'carved in stone' formats for serial keyboards so you should decode each keypress as I've stated above.
PostPosted: Sun Oct 23, 2011 5:31 pm     Reply with quote
short summary:
If you know the ASCII code for the 8 bit char you want to compare
it is just that 8 bit unsigned number compared to the var.
I suggest the VAR be either byte or unsigned int8
otherwise you need to cast the value.
if ( var==ascii_code ) { action(); etc();  }
Gabriel
PostPosted: Mon Oct 24, 2011 6:55 am     Reply with quote
hey all, thanks for your replies...
yeah.. i agree, the ascii code should work fine.... Duh!
however, the # character when used as:
IF(var=='#'){blah;}
does give me an error, and shows up in Green like when used in a #device statement.... maybe im missing somthing...
thanks for your help....i cant believe i didnt think about using the hex value of #.....
sad thing is i posted last week a comment to some other guy related to the interpretation of characters in terminals.... i should sleep,
thank you all...
G
PostPosted: Mon Oct 24, 2011 9:41 am     Reply with quote
is best to assume
that #, _
and possibly other reserved characters used as compiler directive prefix
symbols could share the same fate
HEX or decimal constants are always safe tho ;-))
PostPosted: Tue Oct 25, 2011 2:26 am     Reply with quote
IF(var=='#'){blah;}
thank you all...
G
Just took the experiment, of trying this, with a crude test program.
Tested with 3.249, 4.099, 4.118. None complained.
//With header and RS232 setup:
void main(void) {
   int8 kval;
   do {
       if (kbhit()) {
         kval=getc();
         if (kval=='#')
            putc('M');
            putc('n');
   } while(TRUE);
One 'reason', would be if there was something a line or two earlier, that is looking for the '#'. You _may_ be hitting the old CCS problem of not seeing an earlier syntax error, that then makes a latter line complain, and it just happens to be the #, that is triggering this. Another possibility is that 'IF' in upper case, is the preprocessor form, and the compiler will complain about this if #case is selected.
So though using a hex value has solved the problem, you might want to look at your syntax round the area with a fine tooth comb.
Gabriel
PostPosted: Tue Oct 25, 2011 6:43 am     Reply with quote
Hi!... thanks for diggin deeper...
ill check it out tonight when i get home, and post the code tomorrow morning as well...or my findings... which ever comes first...
Thanks!
G
