Steffe
can't start RTC with setup_rtc(RTC_ENABLE, 0); on 18F27J53 |
Posted: Fri Oct 14, 2011 3:52 am |
Hallo,
Can't set the date and time and with
Code: | rtc_read(&read_clock);
I alway read the same time. I to want to use the internal clock and PLL for my USB and A6 /A7 as IO pins. The code I have reduced to check the RTC functionality.
Does have somebody a idea why RTC can't start ?
Great thanks for hints
Steffe
#include <18F27J53.h>
#FUSES NODEBUG
#FUSES NOXINST
#FUSES STVREN
#FUSES NOPROTECT
#FUSES NOIESO
#FUSES NOCPUDIV // no CPU Clock Division ist 00
#FUSES INTRC_PLL_IO // use A6 and A7 as IO
#FUSES INTRC_IO // use A6 and A7 as IO
#fuses PLLEN // PLL aktivieren
#FUSES PLL2
#FUSES RTCOSC_INT // RTC internal clock
// #use delay(clock=48000000)
#use delay(clock=8000000)
#DEFINE LED1 PIN_C2
#ifndef LED_ON
#define LED_ON(x) output_high(x)
#ifndef LED_OFF
#define LED_OFF(x) output_low(x)
rtc_time_t write_clock, read_clock;
int8 sec_old;
memset(&write_clock, 0, sizeof(rtc_time_t));
memset(&read_clock, 0, sizeof(rtc_time_t));
write_clock.tm_year = 11;
write_clock.tm_mon = 10;
write_clock.tm_mday = 13;
write_clock.tm_wday = 4;
write_clock.tm_hour = 13;
write_clock.tm_min = 6;
write_clock.tm_sec = 7;
setup_rtc(RTC_ENABLE, 0); //enables internal RTCC
rtc_write(&write_clock); //writes new clock setting to RTCC
sec_old = 0;
rtc_read(&read_clock); //reads clock value from RTCC
sec_old = read_clock.tm_sec;
LED_ON(LED1);
while(1){
if( sec_old != read_clock.tm_sec ){
LED_OFF(LED1);
Steffe
Re: can't start RTC with setup_rtc(RTC_ENABLE, 0); on 18F27J |
Posted: Fri Oct 14, 2011 7:36 am |
Hi again,
Just for info, I'm using compiler version 4.125
in hope somebody can give me a hint.
great thanks
Steffe |
Posted: Fri Oct 14, 2011 1:37 pm |
Quote: | #include <18F27J53.h>
#FUSES NODEBUG
#FUSES NOXINST
#FUSES STVREN
#FUSES NOPROTECT
#FUSES NOIESO
#FUSES PLL2
The first thing you need to do is to fix your fuses. First you tell the
compiler to use the Internal Oscillator with the PLL, then in the next
line, you tell it to use the Int. Osc. without the PLL. Then you have
two more PLL fuses.
Fix your fuses. Then make a small program that toggles an LED on and
off at 1 Hz. Check it with a stopwatch, or some other method. Make sure
your PIC is really running at the frequency that you specify in the #use
delay() statement.
What frequency do you really want to use for the PIC ?
The RTC module is normally used with the Timer1 oscillator. A 32.768 KHz
watch crystal (and capacitors) is connected externally to the PIC, on the
Timer1 oscillator pins. Do you have that external crystal circuit connected ?
Also, is this project being tested in real hardware or is it Proteus ? |
Steffe
Posted: Fri Oct 14, 2011 3:13 pm |
Hello PCM programmer,
oh oh yes that doesn't work together thank you,
Now I changed the code and circuit using external crystal 32,768kHz on T1OSO and T1OSI.
After the call "setup_rtc(RTC_ENABLE, 0);" the crystal begins to work I can see, but still I can't see with my LED Test the RTC second is counting.
I miss something like write enable because if I write and read to the rtc date and time I can't see some changes on the timer.
I work with my one circuit, made a solid PCB, USB is working with 48MHz, my SPI bus works also. But my RTC,
hope you have a idea ?
Great thanks
Steffe
here is my new code
#define ADC=10
#FUSES NODEBUG
#FUSES NOXINST // keine extendet Funktionen
#FUSES NOPROTECT
#FUSES NOIESO
#FUSES NOCPUDIV // keine CPU Clock Division ist 00
#FUSES INTRC
#FUSES SOSC_HIGH
#FUSES RTCOSC_T1
int8 i, sec_old;
set_tris_c(0b10111010);
sec_old = 0;
output_high(PIN_C2); // LED ON
while(1){
output_low(PIN_C2); // LED OFF
Posted: Fri Oct 14, 2011 5:47 pm |
Do you have capacitors on the 32.768 KHz watch crystal pins ?
The PIC data sheet recommends 12pf ceramic capacitors.
Are you using the "F" or the "LF" version of the PIC ? If you have the
"F" version, you must have a 10 uF capacitor, low esr, ceramic cap on
the VCAP/VDDCORE pin of the PIC. Do you have it ? This is it:
http://search.murata.co.jp/Ceramy/image/img/PDF/ENG/GRM21BF50J106ZE01.pdf
Note: The cap listed above is no longer manufactured. See the following
link for replacements:
https://www.digikey.com/en/products/detail/murata-electronics/GRM21BF50J106ZE01L/587391
If you have the "LF" version, there are other instructions given in this section:
Quote: | 2.4 Voltage Regulator Pins
(VCAP/VDDCORE)
Edited to add link for replacement capacitors.
Last edited by PCM programmer on Fri Apr 28, 2023 10:59 am; edited 1 time in total |
Steffe
Posted: Sat Oct 15, 2011 2:55 am |
Great thanks for this hints.
Yes I have 2 x SMS Ceramic 10pF on the "F" version.
VCAP/VDDCORE direct connected to VDD.
I can see starting crystal if I call the function:
Code: | setup_timer_1(T1_EXTERNAL|T1_ENABLE_SOSC);
or
Code: | setup_rtc(RTC_ENABLE, 0);
Does the function do the connecting TIMER1 -> RTC?
Does it have something with the INTRC setting ?
Hope we can find why the RTC is not starting.
best
Steffe |
Posted: Sat Oct 15, 2011 9:52 am |
You say you have the "F" version, and that you have
connected the VCAP/VDDCORE pin to Vdd. But that's
wrong. On the "F" version, you should not connect
that pin to Vdd. The PIC data sheet says:
(VCAP/VDDCORE)
On âFâ devices, a low-ESR (< 5?) capacitor is required
on the VCAP/VDDCORE pin to stabilize the voltage regulator
output voltage. The VCAP/VDDCORE pin must not be
connected to VDD and must use a capacitor of 10 uF connected
to ground. |
If you have the "F" version, and you connected the Vdd voltage to the
VCAP pin, you might have damaged part of the PIC. The data sheet says:
Quote: |
31.0 ELECTRICAL CHARACTERISTICS
Voltage on VDDCORE with respect to VSS......... -0.3V to 2.75V
What is your Vdd voltage ? Is it +3.3v ?
Quote: |
⢠Operating Voltage Range of 2.0V to 3.6V
⢠On-Chip 2.5V Regulator
If your Vdd is 3.3v, this would mean that you connected +3.3 to the
output of the 2.5v regulator. I don't know what that would do, but it
is a violation of the data sheet. It's possible that you damaged the PIC. |
Steffe
Posted: Sat Oct 15, 2011 11:57 am |
Great thanks for your info, yes "F" version needs a cap, huuu....
I made the change on a new PCB with a new 18F27J53.
But still my RTC doesn't work on both, my simple test program and USB test for display the date and time.
I did another test with an external CPU crystal (12MHz) HSPLL, but no success.
I did a another test with RTCC_unlock() like
http://www.ccsinfo.com/forum/viewtopic.php?t=44482&highlight=rtccunlock
but it doesn't help, every rtc_read(..) the same value,
do you have another idea ?
in hope best
Steffe |
Posted: Sun Oct 16, 2011 5:56 pm |
I looked at the .LST file. In vs. 4.125, the 18F27J53 has bugs in the
rtc_read() and rtc_write() functions. They are using the wrong addresses
for the RTCVALH and RTCVALL registers. That's why your program
doesn't work.
I will try to write some work-around code to replace the bad functions
but it will take some time and I can't post it until tomorrow at the earliest.
(And I don't work for CCS). |
Posted: Mon Oct 17, 2011 12:01 am |
Here is a quick substitute function for the CCS built-in function.
I called it "my_rtc_read()". Try using it instead of the CCS function.
See if it works. Sample code is shown below. You should edit the
main() code a little to make it use your loop code with the LED.
Normally I spend some time and make a macro that can be substituted
for the CCS built-in function, and it has the same name as that function,
and it has almost identical ASM code. But I just don't have the time (or
the desire, because CCS will certainly fix this problem in the next
compiler version). I'll email CCS about the bug, unless you want to do it.
#define ADC=10
#FUSES NODEBUG
#FUSES NOXINST
#FUSES NOPROTECT
#FUSES NOIESO
#FUSES NOCPUDIV
#FUSES INTRC
#FUSES SOSC_HIGH
#FUSES RTCOSC_T1
char bcd2bin(char bcd_value)
char temp;
temp = bcd_value;
// Shifting the upper digit right by 1 is
// the same as multiplying it by 8.
temp >>= 1;
// Isolate the bits for the upper digit.
temp &= 0x78;
// Now return: (Tens * 8) + (Tens * 2) + Ones
return(temp + (temp >> 2) + (bcd_value & 0x0f));
#byte RTCCFG = 0xF3F
#byte RTCVALL = 0xF3A
#byte RTCVALH = 0xF3B
#bit RTCPTR0 = RTCCFG.0
#bit RTCPTR1 = RTCCFG.1
void my_rtc_read(rtc_time_t *data)
RTCPTR0 = 1;
RTCPTR1 = 1;
data->tm_year = bcd2bin(RTCVALL);
data->tm_yday = bcd2bin(RTCVALH);
data->tm_mday = bcd2bin(RTCVALL);
data->tm_mon = bcd2bin(RTCVALH);
data->tm_hour = bcd2bin(RTCVALL);
data->tm_wday = bcd2bin(RTCVALH);
data->tm_sec = bcd2bin(RTCVALL);
data->tm_min = bcd2bin(RTCVALH);
my_rtc_read(&read_clock);
Steffe
Posted: Mon Oct 17, 2011 3:35 am |
it Works! Jubiii ...
My USB test modified shows the seconds as well.
Great thanks for your professional and quick help and spending time for me on weekend.
So I'll send to CCS a bug report. I learned a little more ASM and register settings
thanx again
best
Steffe |
