SPI on the PIC24FJ256
AlisonP
PostPosted: Thu Oct 13, 2011 8:56 am     Reply with quote
I am trying to use the SPI bus on the PIC24FJ256. I need to use it to communicate with an ADC and a DAC on the same lines.
To setup the SPI up for the ADC I am using the following:
#define SPI_PIN_SCL     PIN_G8 //o
#define SPI_PIN_SDI     PIN_G6 //i
#define SPI_PIN_SDO     PIN_G7 //o
#use spi(SPI1, MASTER, DI=SPI_PIN_SDI, DO=SPI_PIN_SDO, CLK=SPI_PIN_SCL, BITS=8, MSB_FIRST, SAMPLE_RISE, IDLE=0, BAUD=2000000, STREAM=SPI_DAC)
However, the DAC needs SAMPLE_RISE. How can I change this on the fly?
Thanks,
Ali
PostPosted: Thu Oct 13, 2011 9:43 am     Reply with quote
To change SPI formats on the fly use spi_setup(), spi_read() and spi_write() instead of #use spi.
AlisonP
PostPosted: Fri Oct 14, 2011 1:36 am     Reply with quote
Thanks for the reply, but how do I select the correct pins for the SPI using the spi_setup() command? The PIC24 has mapable pins but the CCS documentation does not mention it.
Anyone know?
Ali
PostPosted: Fri Oct 14, 2011 1:59 am     Reply with quote
PCD has the #pin_select statement for peripheral pin selection. You can expect that it works correctly in a recent version.
AlisonP
PostPosted: Fri Oct 14, 2011 2:30 am     Reply with quote
I have added my pin setups like this:
#pin_select SDO1=PIN_G7
#pin_select SDI1=PIN_G6
#pin_select SCK1OUT=PIN_G8
... and it is working, I can see SPI data and clock on the correct pins. So thanks for that.
I have tried to change the hi-low option by adding these lines at the top of functions that write / read to the ADC and DAC, but it still changes the data on the rising edge for both.
ADC
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_4);
DAC
setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_4);
There are only 4 functions that talk to these devices so I am confident that I have added it to them all. Any more ideas?
Many thanks.
Ali
PostPosted: Fri Oct 14, 2011 3:19 am     Reply with quote
Assuming you are using a recent PCD version >= 4.109, both setups refer to the same active clock edge.
In the CCS PIC24 syntax, SPI_XMIT_L_TO_H has to be added to change active edge. SPI_H_TO_L has been renamed SPI_SCK_IDLE_HIGH, review the processor *.h files.
I previously posted some comments about inconsistencies and silent changes of PCD SPI functionalilty and am somewhat tired of the topic. In case of doubt, you'll need to check which SPI mode bits are actually set by your code and possibly correct it.
As an additional point. You possibly need to set setup_spi(false) before applying the new mode setting.
AlisonP
PostPosted: Fri Oct 14, 2011 4:35 am     Reply with quote
Thank you for this advice, it has fixed my problem. I was looking in the help for the correct parameter labels *silly me*. I find it quite annoying that they have changed the compiler but not in the help. I suppose the lesson for me is always look in the 24*.h file.
I spent the best part of yesterday trying to solve this. I was trying to write directly to the correct SFR bit to change the SPI edge and it would not accept it (I am an old school assembler programmer - hehe). If I didn't have my '#use spi' line in it worked but otherwise I wrote to the bit and nothing happened. :rollseyes: I had tried setup_spi first (I found the #pin_select's when I went back to an earlier version) but because I had the wrong parameter name I was doomed and I gave up on it.
Anyway, I understand you are bored with the topic if you have been talking about it for a while, so thank you very very much, your help is greatly appreciated. Very Happy
Ali
