TM1812 Protocol 1 wire
horizontechno
PostPosted: Fri Oct 07, 2011 8:19 pm     Reply with quote
Hi
I need help for using TM1812 led driver from TITANMEC.
The protocol use 1 wire for data and the data protocol are
0 level 24US for reset, and after 96 bit ( 12 X 8 bit ) for led level.
The problem are the 0 and 1.
The 0 is |````|________| high for 320ns and low for 600ns
The 1 is |_______|`````| low for 600ns and high for 320ns
Is very fast
Can I use uart or spi to make this kind of data ?
Now I try with pic 18f4520 at 40MHz.
Thank for your help.
alain tanguay
horizontechno
PostPosted: Fri Oct 07, 2011 8:22 pm     Reply with quote
Sorry for my drawing i have make mistake this is the good one.
The 0 is |````|________| high for 320ns and low for 600ns.
The 1 is |¨¨¨¨¨¨¨|_____| low for 320ns and high for 600ns.
Alain
PostPosted: Fri Oct 07, 2011 10:10 pm     Reply with quote
If you want help on writing a driver for a chip, then post a direct link
to the PDF file for the data sheet.
horizontechno
PostPosted: Mon Oct 10, 2011 6:48 pm     Reply with quote
The datasheet are only in Chinese, now is working, but i cannot change the PWM very fast ?
I looking to find which kind of protocol is this ? and if a can emulate with SPI UART or other ?
Alain Tanguay
PostPosted: Mon Oct 10, 2011 7:32 pm     Reply with quote
We don't have any link to a data sheet (in English).
So we can't help.
