aaronik19
MCP23008 |
Posted: Mon Oct 10, 2011 3:12 pm |
Dear All,
I am using about 4 IO Expander on one single I2C bus. The configuration is below:
// MCP008 REGISTERS
#define _IODIR 0x00
#define _IPOL 0x01
#define _GPINTEN 0x02
#define _DEFVAL 0x03
#define _INTCON 0x04
#define _IOCON 0x05
#define _GPPU 0x06
#define _INTF 0x07
#define _INTCAP 0x08
#define _GPIO 0x09
#define _OLAT 0x0A
void init_MCP23008() {
output_float(PIN_B1);
output_float(PIN_B0);
delay_ms(250);
void write_MCP23008(unsigned char WriteAddress, unsigned char cmdByte, unsigned char data)
i2c_start(); // start condition
delay_us(20);
i2c_write(WriteAddress); // Send slave address and clear (R/W_)
delay_us(20);
i2c_write(cmdByte); // Command byte and register to be written.
delay_us(20);
i2c_write(data); // First data byte pair as per command byte(cmd)
delay_us(20);
i2c_stop(); // stop condition
delay_us(50);
long int read_MCP23008(unsigned int WriteAddress, unsigned int cmdByte, unsigned int ReadAddress)
unsigned int data;
delay_us(20);
delay_us(20);
delay_us(50);
i2c_start();
delay_us(20); // restart condition
i2c_write(ReadAddress); // Send slave address and clear (R_/W)
delay_us(20);
data = i2c_read(0); // Data from LSB or MSB of register
delay_us(20);
return(data);
and the main program is this:
#include "i2c.c"
#define MCP23008_write_add 0x40
#define MCP23008_read_add 0x41
write_MCP23008(0x01, _IODIR, 0x00);
write_MCP23008(0x02, _IODIR, 0xFF);
write_MCP23008(MCP23008_write_add, _IPOL, 0x00);
write_MCP23008(MCP23008_write_add, _IOCON, 0x00);
init_mcp23008();
write_MCP23008(0x01,0x09, 0x01);
delay_ms(3000);
write_MCP23008(0x02,0x09, 0x02);
delay_ms(3000);
write_MCP23008(0x03,0x09, 0x03);
delay_ms(3000);
write_MCP23008(0x04,0x09, 0x04);
now I have the 4 IO Expander from address 0x01 to 0x04. When I am reading I am getting always 0xff. I am making something wrong? Thanks for your help to solve this issue. I am using PIC18F4550 with 20MHz crystal. |
Posted: Mon Oct 10, 2011 4:26 pm |
The addresses of 0x40 and 0x41 are for your first MCP23008.
The sub-address of each separate MCP23008 chip is contained in the
control byte. It's defined by 3 bits (A0, A1, A2).
Download the MCP23008 data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/21919d.pdf
Look at Figure 1-2 at the top right of page 8. You can see how if
the chip had a sub-address of 0 (A0, A1, A2 all connected to ground)
then the chip would have an i2c address of 0x40 (and 0x41 for reading).
So, you need to #define the control bytes for the other 3 MCP23008
chips. Look at the bit diagram and decide how to do it. Then write
the new #define statements. Then use those in your code to talk
to the specified chip. |
